  • Guests: 31
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
2 Channel High Voltage Oscilloscope Probe.
Thu Jun 30 2011, 02:17AM
Purpose: To measure NST's to high accuracy, learn measurment techniques and provide a common standard for HV calibration of other instruments.
Background and previous threads:
Link2 (NST HV measurement) (True RMS error! ,Realized 6/20/2011)
Link2 (HV Diode making)
Link2 (Mearsuring HV resistors to high accurracy)
Link2 (HV resistors, Project)
Link2 (Pots and HV measurements)
Link2 (About Bio-Oils for HFHV Transformers.)
Link2 (Capacitive Voltage divider, for O-scopes (10,000:1))
Specs:
For use on 1X setting.
1M ohm input impedance scopes.
11kV instantaneous peak voltage to ground max.
Olive oil (food oil) filled, for heat and insulation.
1000:1, 100M ohms input impedance, either channel.
For less than 1kHz Vac, or DC use.
The device as built w/USB Oscope.
Pics
1309459725 2431 FT1630 Twinch
Schematic as built.
1309407191 2431 FT1630 Nst
Device Under Test, DUT, Neon Sign Transformer.
1309410334 2431 FT1630 Nst2
Franceformer NST, the DUT.
1309502323 2431 FT118895 Oscill1
Here the "wobbly sine wave" can be seen, and the true RMS measurements can be seen too. This ratio is accurate.
1309502323 2431 FT118895 Oscill2
Here the invert feature was use to compare the waves, the blue trace is always about 1 pixel higher in voltage than the green trace. The ratio of divison is not accurate, thus the 10.4V vs 9.4V difference.
Fri Jul 01 2011, 06:38AM
New pics!
Here the "wobbly sine wave" can be seen, and the true RMS measurements can be seen too. this ratio is accurate.
here the invert feature was use to compare teh waves, the blue trace is always about 1 pixel higher in voltage than the green trace.the ratio of divison is not accurate, thus the 10.4V vs 9.4V difference.
Corey
Fri Jul 01 2011, 08:32AM
Corey Registered Member #1902 Joined: Fri Jan 02 2009, 07:59PM
Very interesting thread you have here, but why double post?
Sat Jul 02 2011, 01:25AM
Corey wrote ...
If im not mistaken, the project forum rules allow the starter to post new info(to get to the top) and then were supposed to update all changes to the first post, for ease of viewing. (it also helpsme keep a time stamp on my progress.)
EDIT: (From Admin, project forum rules)
* All information needs to be consolodated to the very first post in the thread. You may post short posts in your thread stating that you've updated your project thread, keeping in mind the double posting rule, but any actual updating needs to be done by modifying the very first post in the thread.
