  • Guests: 74
Electromagnetic Projectile Spin
kjjohn
Fri Sept 10 2010, 10:27PM Print
kjjohn Registered Member #2985 Joined: Fri Jul 09 2010, 04:05PM
I have seen a few coilgun designs in which a spin is induced for accuracy on the bullet using magnetic coils. How does this work? Could it be used for faster types of propulsion? I think the advantage is that this would not decrease performance as much as rifling.
Fri Sept 10 2010, 10:40PM
Awhile ago, I asked this question to the guy working on this here: Link2 Apparently He uses a slotted projectile (not 100% rotational symmetry) and spins it like a single pole reluctance motor... maybe me means two pole...
Theres also the design for another one here: Link2
and I don't think rifling would work unless you used a grooved projectile.
Hope that helps
-Ken
Sat Sept 11 2010, 06:45PM
I thought I posted a reply to this last night, but apparently I never bothered to hit the send button.
If your projectile was a permanent magnet, and polarized diametrically, instead of axially, it would probably be possible to induce spin on the projectile with small 'kicker' coils outside the barrel at strategically placed locations, but it wouldn't be simple.
Realistically the best way to impart spin would probably be to use a spindle that gripped the projectile with an electromagnet, and kept the projectile centered in the barrel to avoid uneven friction. The spindle would then be turned by a regular motor to impart spin. When the propulsion coil fired, the electromagnet on the spindle would release. If you did it with a high enough degree of precision, you'd probably avoid too high a degree of friction or chatter in the barrel caused by the spin.
-Dave
Artikbot
Wed Sept 29 2010, 10:17AM
Artikbot Registered Member #3247 Joined: Mon Sept 27 2010, 09:42AM
Wow the motor idea is great to induce spin on a projectile! Also quite easy, everything has to be said.
I was thinking about a slotted projectile and slightly turned coils to periodically spin the bullet. But that requieres a multistage design.
