  • Guests: 44
capacitor bank issues...please help!
teslasapprentice
Thu Jul 29 2010, 08:35AM Print
teslasapprentice Registered Member #2996 Joined: Tue Jul 13 2010, 12:23PM
okay so i built three capascitor banks and i put diodes on each bank to allow all banks to be charged at the same time but disharged seperatly, but the problem is is that when i discharge one of the banks all three of them disharge at the same time...
EDIT: oops...my question is, is does anyone know why this is happening, i got the idea from a schematic on anothercoilgunsite.com
Saz43
Thu Jul 29 2010, 09:47AM
We could better help you if you post a diagram.
teslasapprentice
Thu Jul 29 2010, 08:03PM
sorry about that, here ya go
Parallelcharging1
IntraWinding
Thu Jul 29 2010, 09:42PM
Either the diodes have gone closed circuit, or you built it differently to the diagram.
Pinky's Brain
Thu Jul 29 2010, 09:53PM
Are you testing with a real circuit? If you were just testing the general method with small caps and by shorting one bank the reverse recovery time of the diodes could play a role (not so much an issue in a real circuit since the discharge time >> reverse recovery).
Otherwise a simple mistake or the diodes having failed short (what's the max charging current?) is indeed the only explanation.
teslasapprentice
Fri Jul 30 2010, 12:56AM
i figured out the problem....my diodes had fried so they were letting current flow both ways, i went out and bought new bigger diodes and it works awesome now ^_^
Fri Jul 30 2010, 12:29PM
teslasapprentice wrote ...
Thats good to hear!
