  • Guests: 34
williamn (48)
ReddyK (57)
Birdman (31)
12/13 williamn (48)
12/13 ReddyK (57)
12/13 Birdman (31)
SCR trouble
woxxey
Fri May 29 2009, 06:06PM Print
woxxey Registered Member #1906 Joined: Sat Jan 03 2009, 05:06PM
I can't get this SCR working.
Are all SCRs suppost to be connected in the same way?
(The - of both power sources to K, + of HV to A & + of trigger source to G)
Could you recomend an easy wayto test if a SCR is working or not? 2 batterypacks of 3v and some light emitting diodes)
Sat May 30 2009, 12:42AM
I usually test with a 12v battery (car battery, or a lantern battery) and a 12v incandescant bulb. This takes more current than an LED and therefore avoids any chance that the SCR turns itself off at that low current. A car headlamp will probably draw 3 amps (36 watts) or so.
Good luck, Barry
I have enough money to last me the rest of my life, unless I buy something. (Jackie Mason)
