  • Guests: 64
uzzors boost converter?
Solidacid
Wed May 06 2009, 05:19PM Print
Solidacid Registered Member #1430 Joined: Sun Apr 06 2008, 11:12AM
hey there :D
yesterday i finished my boost converter built from uzzors schematic.
to test it i'm using a photoflash capacitor
i having some trouble with it:
- i'm not hearing the whine that is noted in the description
- i can't make i charge higher than 150V
- i tried different inductors(i don't have an LC meter and i have no idea what range my inductors are in) with some, the MOSFET gets VERY hot before even reaching 50V, and with others it stays cool till it reaches 150V(after about a minute) and stops there
i'm pretty sure i'm using a powerfull enough powersupply, i tried: a bank of AA's, a bank of C's, my variable powersupply and a 12V transformer.
any ideas what i might be doing wrong?
Pics:
img 1
img 2
img 3
woxxey
Thu May 07 2009, 05:28PM
woxxey Registered Member #1906 Joined: Sat Jan 03 2009, 05:06PM
My stopped at 150 as well just after being finnished, and i posted a similar thread:
The problem in my case was the 10k & 12k resistors connected to pin 3 on the LM311. Originally I used one 22k resitor there but i then changed it for a variable one ranging from 0k-35k, which solved it for me.
By the way, I am using an 150uH inductor.
Solidacid
Thu May 07 2009, 08:34PM
i found the problem amazed (well, one of them tongue)
i checked my entire circuit(again) and found that i had put a wrong capacitor between the 555 and ground. i switched it and immediately heard a whine amazed
now i just need to play with timing and inductors to make it charge faster shades
Saz43
Fri May 15 2009, 01:39AM
Does anyone know how much current this circuit draws?
cereus
Fri May 15 2009, 03:54AM
cereus Registered Member #1920 Joined: Sat Jan 10 2009, 02:10PM
My circuit draws 3A at 12V (loading 1000µF to 300V in 5 seconds).
Camel
Fri May 15 2009, 07:12AM
Camel Registered Member #1694 Joined: Sat Sept 13 2008, 09:13AM
cereus wrote ...
Thats 25% efficient!! I wonder if efficiency would be improved by paralleling 2 IRFP250s . .
Saz43
Fri May 15 2009, 07:24AM
cereus wrote ...
Thanks!
GeordieBoy
Fri May 15 2009, 10:56AM
A flyback converter would be much more efficient for this high step-up ratio. Stepping up 12V to 300V is extreme for a boost converter.
-Richie,
Saz43
Wed May 20 2009, 08:53PM
A question:
When my friend and I first built this circuit, we encountered the following problem. Note that we powered it with an Airsoft gun battery rated at 12V with a max current supply of 30A.
First, the circuit worked but only charged our caps to ~200V then shut off. This problem has been addressed numerous times on these boards (frequency/inductor mismatch).
But then, the oddest thing happened. The circuit began charging the capacitors, but when reaching around 200V it started making odd noises (the characteristic whine changing pitch). I shut it off because I didn't know what was going on and the components were getting hot. Upon trying a third time, the circuit immediately drew so much current from my battery that the input wires almost melted off. The MOSFET and 555 were cooked.
Any ideas? Everything was built to spec except for the inductor, which we pulled off of some junked circuit board. I'm trying a rebuild this weekend.
nerdywarrior
Thu Jun 04 2009, 03:07AM
nerdywarrior Registered Member #2139 Joined: Mon May 25 2009, 07:54AM
Does anyone know a source where I can buy the 500V 15A Diode? My usual sources have expensive minimums or dont have it at all
