  • Guests: 67
connecting SCR's
hotcrazyfruit
Fri Mar 20 2009, 04:21AM Print
hotcrazyfruit banned on 5/26/2009
Registered Member #1877 Joined: Mon Dec 22 2008, 02:03AM
ok so, i have about 18, 610 amp rated SCR's iv been thinking of ways to connect them, and my acquaintance insists on mounting them on a PCB. keep in mind that that there will be about 12500 amp pulses going through there. with 1.5" traces, on a pcb, do you think it will be enough to conduct without causing too much resistance? or even blowing the PCB?
teslacoolguy
Fri Mar 20 2009, 04:57AM
That should be ok. What kind of pcb copper are you using eg: 1oz 2oz and so on? I would personally recommend 5oz but lower should work fine. You can also solder additional copper on top of the traces to make them more robust if you are still concerned.
yottaKVA
Fri Mar 20 2009, 05:01AM
yottaKVA Registered Member #1618 Joined: Sun Aug 03 2008, 09:38PM
Location: Brooklin, Ontario, Canada, North America, Planet Earth, Solar System, Milkyway galaxy, Universe...
Would these SCRs happen to be the through-hole ones sampled from ST microelectronics? Concerning your question, that would depend on the thickness of the copper in the traces. It might be possible to solder additional wire to the bottom of the SCR leads under the PCB to help reduce resistance and help increase its ability to handle the current. It seems to me that that a PCB would be the only way to efficiently connect a whole whack of through-hole SCRs in parallel, anyone else have any better ideas? What style of terminations are you thinking for connecting to the PCB, large bolts with washers maybe? Also, it seems as if you rely quite heavily on this "Acquaintance's" advice xD. I'm not an expert concerning PCBs maybe someone else can take over from here.
*** lol you posted just before me but i posted on the duplicate thread :)
[EDIT] and teslacoolguy said the same thing as me just more concisely, slow keyboard buffer...
Fri Mar 20 2009, 11:46AM
Duplicate thread dudes, please use one thread only. I've locked this one and will delete it in a couple of days.
