  • Guests: 322
Iniaes (17)
nelsonic (17)
Reid (33)
10/23 Iniaes (17)
10/23 nelsonic (17)
10/23 Reid (33)
connecting SCR's
hotcrazyfruit
Fri Mar 20 2009, 04:21AM Print
hotcrazyfruit banned on 5/26/2009
Registered Member #1877 Joined: Mon Dec 22 2008, 02:03AM
ok so, i have about 18 610 amp rated SCR's iv been thinking of ways to connect them, and my acquaintance insists on mounting them on a PCB. keep in mind that at making there will be about 12500 amp pulses going through there. with 1.5" traces, on a pcb, do you think it will be enough to conduct without causing too much resistance? or even blowing the PCB?
teslacoolguy
Fri Mar 20 2009, 04:53AM
must have been a glitch as this thread got posted twice. Can a mod delete it?
yottaKVA
Fri Mar 20 2009, 04:58AM
yottaKVA Registered Member #1618 Joined: Sun Aug 03 2008, 09:38PM
Location: Brooklin, Ontario, Canada, North America, Planet Earth, Solar System, Milkyway galaxy, Universe...
Would these SCRs happen to be the through-hole ones sampled from ST microelectronics? Concerning your question, that would depend on the thickness of the copper in the traces. It might be possible to solder additional wire to the bottom of the SCR leads under the PCB to help reduce resistance and help increase its ability to handle the current. It seems to me that that a PCB would be the only way to efficiently connect a whole whack of through-hole SCRs in parallel, anyone else have any better ideas? What style of terminations are you thinking for connecting to the PCB, large bolts with washers maybe? Also, it seems as if you rely quite heavily on this "Acquaintance's" advice xD. I'm not an expert concerning PCBs maybe someone else can take over from here.
big5824
Fri Mar 20 2009, 09:26AM
12500 amps is probably going to vapourise a pcb, you need to use solid aluminium or copper to connect everything
hotcrazyfruit
Fri Mar 20 2009, 02:36PM
big5824 wrote ...
thats exactly what i was thinking...
hotcrazyfruit
Sat Mar 21 2009, 12:42AM
yottaKVA wrote ...
LOL fuck you austin!! lmfao jookes XD
Sat Mar 21 2009, 01:00AM
Locked due to foul language, useless one-liner posts and general poor quality
