  • Guests: 42
CT2 (37)
Josh Johnson (46)
01/21 Banana Man (41)
01/21 TheAnomaly (13)
01/23 GimpyJoe (36)
First time coil gun.
Mattc1886
Tue Feb 10 2009, 07:56PM Print
Mattc1886 Registered Member #1968 Joined: Tue Feb 10 2009, 07:47PM
I am very interested in building a low power coil gun. I have been searching online but am having a little trouble finding information for someone with no experience. I would like to build a very basic coil gun using batteries as a power supply before attempting to move to something bigger. Thank you for any help.
teslacoolguy
Tue Feb 10 2009, 08:01PM
Read through Barry's website Link2 there is more then enough information on that site for building your first coilgun. For the power supply i would look into a simple boost converter design like uzzor's made on his website Link2 I hope this helps you a lot.
aonomus
Tue Feb 10 2009, 09:12PM
Read the HvWiki (left hand menu) to try and find more information ( Link2 )
Also, use google to look up information, most information is out there on the internet, and here on the forums in older posts. Use google, the search function, and try wikipedia as well. We can only really help people who have done their own background research.
Tue Feb 10 2009, 09:22PM
In particular, my website has a coilgun powered by two 12v lantern batteries which was built in a cheap plastic toolbox. It gains efficiency by surrounding the coil with laminated iron that was liberated from an old transformer core. It was built in 2003 and I'm still using the same two batteries.
Let me know if you want more photos (e.g. interior views) let me know and I can easily add them to my web site.
I guess I don't really understand the fascination with boost converters. They seem to be popular, but if I want high voltage at decent current then I'll simply use a transformer plus diode bridge. It doesn't get any simpler and easier than that.
Cheers, Barry
The road to success is always under construction.
Mattc1886
Tue Feb 10 2009, 09:57PM
Thanks for your help. Barry your site is very helpful and will hopefully lead to my first coil gun!!! Will probably have lots more questions but for now Im off to get more supplies.
Mattc1886
Thu Feb 12 2009, 07:05PM
I've been trying to wind my coil and so far have been unable to get it as neat and tight as I would like. Does anyone have any useful tips?
KLH
Thu Feb 12 2009, 07:15PM
Mattc1886 wrote ...
How are you winding your coil? Whatever you do, DON'T hold the coilform still and rotate the wire around the coilform. This will twist the wire and evetually it will start to bend and cause your coil to deform. Instead, find a way to hold the spool of wire still but able to rotate (you can use your hands, but something like a toilet paper roll works too). Then rotate the coilform with one hand (which pulls the wire off of the spool), and guide the wire onto the right place.
Mattc1886
Thu Feb 12 2009, 08:01PM
Woops! Thanks for the tip I am going to try using a power drill to turn the form.
