  • Guests: 64
David (39)
12/25 Kolas (18)
12/26 buxtronix (50)
Infa red trigger
Camel
Fri Feb 06 2009, 07:48AM Print
Camel Registered Member #1694 Joined: Sat Sept 13 2008, 09:13AM
Hi,
I've made myself an infa red switch with a LED and a photodiode. It uses an LM311n to detect the change in voltage across the photo diode as the projectile passes through. It works well, except . . .
When the projectile goes through, the 311 puts out a pulse of negative potential . . . electrons flowing out. Ya can't turn on an SCR with negative potential. I can't find any LM311ps, so thats not really and option, and I have half a million 311ns floating around so I would prefer to use them if I could.
Possible solutions, anyone?
rp181
Fri Feb 06 2009, 01:05PM
Pretend the out put is positive. How would you wire the SCR? Now just swap the gate and cathode leads. Positive will connect to the gate lead, and the lm311 out connects to cathode.
Camel
Fri Feb 06 2009, 02:20PM
Thanks rp! I'll give it a shot tomorrow.
Will this change the rating of the SCR at all? I mean, if I have a 300amp pulse through the gate . . any chance that would fry my SCRs?
big5824
Fri Feb 06 2009, 04:23PM
could just use a NOT gate
KLH
Fri Feb 06 2009, 05:24PM
big5824 wrote ...
It doesn't matter. What if the NOT gate puts out a negative voltage on a high output? You can use a PNP transistor, with the collector tied to the gate of the SCR.
As for the gate current, you should limit it to a short pulse of about 5 to 10A.
Camel
Sat Feb 07 2009, 03:52AM
Here is a schematic I've drawn up
Clicky
PNP collecter is hooked up to teh gate in this schematic . .
Clicky
Should work fine, right??
big5824
Sat Feb 07 2009, 09:38AM
iv never used a 311, but could you just swap the two inputs around?
Camel
Sat Feb 07 2009, 11:30AM
Nah, the output is hi when the + input is highest, and its low when - is higher. Swapping the two inputs around would the output hi until the projectile passes through the detector.
