  • Guests: 36
plazmatron (48)
rm203tech (17)
Duality (16)
Jiffycoil (65)
Dandrion (69)
12/21 Inducktion (32)
12/21 Standa (31)
12/21 nabzim (33)
charging circuits in serie
woxxey
Mon Jan 26 2009, 07:01PM Print
woxxey Registered Member #1906 Joined: Sat Jan 03 2009, 05:06PM
Personally i have no idea wether this would work or not, even though i suspect it won't. But anyway here it goes:
Would connecting camera-flash charging circuits in series give an adequate output for charging camera-flash capacitors connected in series?
guitardude012
Mon Jan 26 2009, 08:03PM
guitardude012 Registered Member #968 Joined: Fri Aug 24 2007, 04:54PM
I don't think it will work. Others around here know more than me about these charging circuits but basically the timing won't synchronize on the outputs.
Lakeowner
Mon Jan 26 2009, 09:15PM
Lakeowner Registered Member #1370 Joined: Mon Mar 03 2008, 09:01AM
In theory it would work, but you must remember to power them from separate supplies (battery) because they will have one capacitor's voltage potential difference.
Backyard Skunkworks
Tue Jan 27 2009, 04:54PM
Laakkonen wrote ...
I've played around with these quiet a bit (I've got 200+) and I can say that they dont seem to run from a single battery. I have managed to develop a few kV from enough of them in series, the best use I've found for them is testing dielectric strength (and shocking people!).
You really should get a better charger for cap banks, but yes, it works.
