  • Guests: 57
Diodes in anti-parallel
hotcrazyfruit
Sat Jan 24 2009, 06:46PM Print
hotcrazyfruit banned on 5/26/2009
Registered Member #1877 Joined: Mon Dec 22 2008, 02:03AM
I have a 1.312 kj capacitor bank, it is 500 volts at 10500 uf. ive been discharging it into a coil recently when i found out about the reverse voltage back into the capacitor bank. sure enough, i measure -100volts on the capacitor bank after discharge! so, i sampled a few diodes from stmicroelectronics, i have 9. they are 1000v @ 60a each. how should i go about hooking them up? i would need a resistor correct? what size of resister? where can i get one? any help is greatly appreciated.
rp181
Sat Jan 24 2009, 07:19PM
You don't need a resistor. Just put them in anti parallel directly. Put a couple if your not sure about rating.
Myke
I think the resistance put in series with the diode should be large enough to keep the peak current under the peak current of the diode (it's more than 60A). Stick the diodes across the cap rails so that the cathode goes on the positive rail and the anode goes on the negative rail. I don't think some people use resistors though.
big5824
Sat Jan 24 2009, 08:48PM
if you use resistors surely the lowest resistance path is then to destroy ur cap bank?
El_Roberto
Sat Jan 24 2009, 08:58PM
El_Roberto Registered Member #1774 Joined: Wed Oct 22 2008, 02:51AM
Well I fire my coilgun at 350j and I dont have a resistor just two 250A peak diodes.
guitardude012
Sun Jan 25 2009, 08:17PM
guitardude012 Registered Member #968 Joined: Fri Aug 24 2007, 04:54PM
I don't use resistors on my current 600J CG but my two diodes add up to a "pulse" rating of over 2kA.
The peak current is sometimes listed as something like 8ms on the datasheet and assumes many things. Look at the current limit graph on the specsheet for the pulse length you are expecting. I would try to get diodes that are rated such that you don't need resistors, but getting ultra fast diodes can sometimes make this impossible/impractical.
hotcrazyfruit
Sun Jan 25 2009, 08:36PM
would the capacitors be damaged by now? i have discharged them into a coil without protection about 10 times now. is there any way to reverse damage to electrolytic capacitors?
guitardude012
Sun Jan 25 2009, 09:35PM
The capacitance has probably decreased as a result of reverse charging to -100v ten times. What are the inductance and resistance of your coil?
big5824
Sun Jan 25 2009, 10:28PM
yea i didnt notice that......surely they would have exploded at -100v
hotcrazyfruit
Mon Jan 26 2009, 04:18AM
i measured -100v only once. be, again, is there any way to reverse the damage? im thinking like memory on batteries, they lose their ability to store their charge if you keep charging them, but i don't think its the same concept. but any ideas?
