  • Guests: 31
Some questions about plasma
ebp
Sat Jan 24 2009, 11:03PM Print
ebp Registered Member #1933 Joined: Sat Jan 24 2009, 10:53PM
Hi i'm making a mini railgun for school project, something similar to this: http://64.233.187.104/search?q=cache:t7YO350tj_4J:www.geocities.com/physicsthings/microrailgu.htm+&hl=en&client=firefox-a. But there is something that got me wondering. Why is aluminum being used? What is the advantages to using aluminum that turns into plasma instead of some conducting material that stays solid? I hope that you can help me understand cheesey
rp181
Sat Jan 24 2009, 11:16PM
your link is not working, seems you linked to a cached version on your computer. I think i know what your talking about though.
You want to keep the projectile intact. This one is so low power its not practical to use a actual projectile. Some railgun's use plasma armeture's. That means the material (usually foil) is vaporized, and the plasma provides the conduction path, which pushes the projectile. If you are going to do that small of a one stick with foil. You will get a ball of sparks going one direction. It's much more impressive looking though =p
ebp
Sun Jan 25 2009, 12:07AM
If you copy this link to your it should work: Link2 it's from google cache. I still don't understand why it has to be vaporized instead of just using a conductive projectile. Is the plasma just for show? :)
Camel
Sun Jan 25 2009, 01:33AM
Camel Registered Member #1694 Joined: Sat Sept 13 2008, 09:13AM
It doesn't have to be vaporised, anything conductive would work. I guess since he was firing a slither of al foil, the plasma was unavoidable.
I've never built or done much research on rail guns, but I think most rail gunners try to avoid the arcing and plasma because its corrodes the rails.
ebp
Sun Jan 25 2009, 06:52PM
Camel wrote ...
Ok thanks :) I think i will avoid plasma then and just use a conductive projectile, since i'm going to do some experiments. Is there a specific material that would be suited for this?
rp181
Sun Jan 25 2009, 07:22PM
any conductive non magnetic projectile. (copper and alu are the easiest)
ebp
Sun Jan 25 2009, 07:50PM
rp181 wrote ...
Thanks, by using material that doesn't turn in to plasma, shouldn't it be easier go get consistent firing?
big5824
Sun Jan 25 2009, 10:29PM
people have used hard plastics before i think
/edit yes with aluminium as the propelent, forgot to mention that
Electroholic
Mon Jan 26 2009, 03:16AM
big5824 wrote ...
with alu tape for plasma generation.
ebp
Tue Jan 27 2009, 08:21PM
I think i'm try out some different thinks, but thanks for the replies :)
