  • Guests: 113
SCR question
Turkey9
Fri Jan 02 2009, 02:45AM Print
HI
I've used parallel SCRs with good results, but because of my supply of parts, I'm wondering if I can add SCRs of different voltage ratings. I have devices that have the same current ratings but are 600, 800, and 1200 volts. They're from the same product line so i'm pretty sure they're closely related apart from the max voltage.
Could I have 2 SCRs for 700v caps, and then add 2 more for using with a 350v bank that would supply more current to a coil?
rp181
Fri Jan 02 2009, 04:03AM
Its fine to parallel, as long as you treat the voltage rating as the SCR with lowest rating.
Turkey9
Fri Jan 02 2009, 04:46AM
Ok and thank you very much!
Myke
Fri Jan 02 2009, 05:01AM
Also you have to remember that the SCRs don't share current exactly equally because of them not being exactly the same. You have to leave a generous amount of headroom max current wise.
