  • Guests: 47
02/03 Bauerb2 (36)
02/04 Fabio (46)
02/04 Corey (35)
Plasma/Arc Repulsion
KLH
Fri Dec 19 2008, 05:54PM Print
After reading many of the threads about coilguns, railguns, and plasma arcs, I wondered if anything such as a plasma repulsion cannon would be feasible. The device would strike an arc between two electrodes with low-power high voltage, and then both the electrodes and a coil directly below the electrodes would be pulsed with high energy from a capacitor bank.
I know it's a vague and random idea, but please tell me what you think.
rp181
Fri Dec 19 2008, 09:56PM
I don't quite understand. Do you mean a air discharge to produce plasma and then a coil to shoot this plasma?
big5824
Fri Dec 19 2008, 11:50PM
yes i think he means to ionise the air and then use a magnetic field to propel the plasma at high speed. Sounds like it could work to me, but i dont exactly know much in the field :)
rp181
Sat Dec 20 2008, 12:21AM
How are you going to make the plasma repel the magnet? Both fields attract plasma.
LithiumLord
Sat Dec 20 2008, 12:33AM
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
Lourenz force - I recall even someone been building an alike device - a copper wire gets vapourized by a cap bank discharge and a hot DC arc appears and gets fired away by a strong magnetic force of a working coil that gets some caps discharge into it as well.
Sat Dec 20 2008, 10:32AM
It is possible, try looking up a 'plasma armature' railgun
rp181
Sat Dec 20 2008, 03:40PM
A railgun would of course work, but this sounds like a pancake coil underneath the plasma. In any case, What is the point of accelerating plasma unless its propeling a projectile? Unless it is very close targets.
LithiumLord
Sat Dec 20 2008, 05:10PM
Yes, as far as I know of alike experiments, the plasma formation obtained by that method could make it only a meter or so, with no noticable destructive power.
Fire off a load of thermite with a potato gun or ETG, now that's going to be a heavy kick! (I didn't say that - for the case anyone tries that out and blows it up ;) )
