  • Guests: 25
buxtronix (50)
12/27 Elliott (35)
12/27 Gratitude (40)
12/27 Swraka (37)
Large SCR as blocking diode?
Kizmo
Sun Dec 14 2008, 10:44AM Print
After i detonated my 2800A stud diode to dead short i began to think what else could be used as protective device. Maybe large SCR? My system uses mechanical spring loaded switch. It seems that high voltage SCR with very large pulse current capability (+30kA) is easier find than diode that size.
Any thoughts?
Camel
Sun Dec 14 2008, 11:03AM
Camel Registered Member #1694 Joined: Sat Sept 13 2008, 09:13AM
A large diode in parallel with the coil, reverse biased to normal current flow. That'd drop inductive kickback down to 0.7V
Kizmo
Sun Dec 14 2008, 11:26AM
It must be one hell of a diode :)
Camel
Sun Dec 14 2008, 11:45AM
How much kickback are you expecting??
Kizmo
Sun Dec 14 2008, 11:56AM
Not sure yet but enough to destroy 2800A(pk) stud diode in few shots. Total bank energy is slightly over 10kJ and it will be quite a bit more soon ;)
Fraggle
Sun Dec 14 2008, 08:17PM
Fraggle Registered Member #1526 Joined: Mon Jun 09 2008, 12:56AM
I used a puck on my electrolytics and it never failed.
rp181
Sun Dec 14 2008, 08:35PM
My thinking is that it is not the peak currents encountered, but the di/dt. The current surge rating goes up alot when time goes down. Try adding resistance to the circuit. What ever place sells SCR's are going to sell diodes that go that high.
