  • Guests: 20
buxtronix (50)
12/27 Elliott (35)
12/27 Gratitude (40)
12/27 Swraka (37)
multi stage, coil launch railgun
David.Lightman
Fri Dec 12 2008, 04:10AM Print
David.Lightman Registered Member #1327 Joined: Mon Feb 18 2008, 12:13AM
I noticed that many high powered railguns need to have a pre launch or at least a means of getting the armature moving prior to triggering. I have always viewed this as somewhat cheating, as the currents are not the sole means of projection. What if you used a coilgun to launch the armature in between the rails and the armature would trigger the railgun.
I am wondering if the coilgun would interfere with the fields of the rails.
D.L
rp181
Fri Dec 12 2008, 05:14AM
The coilgun fires first, then the rails. The interaction of overlapping fields would be insignificant.
Also, you do not need a moving armature. You can have it in the rails, and then turn power on.
Electroholic
Fri Dec 12 2008, 07:07AM
if you wnat to use the coil gun and rail gun with the same projectile, you are pretty much limited to induction launchers.
rectangular projectile would be better for the rail gun part, but the coil gun part would not be easy to do/optimize.
guitarlord66
Mon Dec 15 2008, 10:53AM
guitarlord66 Registered Member #1805 Joined: Sat Nov 08 2008, 06:29AM
Why not make a high powered solenoid to push the aluminum projectile into the rails?
