  • Guests: 67
Arjan EMM (52)
01/01 Bosko (56)
01/01 hen918 (30)
01/01 Yuri_Ivanov (35)
Best method for a multistage?
Killa-X
Wed Dec 03 2008, 03:18AM Print
Well, I guess it's coming to the time where I'm considering adding a 2nd coil. Whats the best way to trigger the 2nd coil on the exact time for best force? By optical light sensors or physical touch using the bullet to complete the circuit?
Also.. If i want 2 coils.. Is it best to have a fairly small one to boost the object, followed by a large one to accelerate? or should they be fairly the same size?
Would be my first multistage when I actually start on it. It's been awhile since I've updated my single stage test coil since I got this new laptop. Work will resume how ever soon. :)
Turkey9
Wed Dec 03 2008, 03:36AM
just add the next coil and tune it for the most acceleration. Use optical sensors to trigger the coil because a mechanical method, although simpler, would slowly wear down and also is less precise.
Myke
Wed Dec 03 2008, 04:30AM
You want the second coil to have a faster rise time and decay time so that the projectile is accelerated while entering the coil. You want the current to decay quickly so that there isn't any suck back. To get faster rise and decay times you can use a higher voltage and/or less inductance for the rise time and less capacitance for the decay time.
I would just say experiment to see what works best. Then you can fine tune it with calculations (or you could do it the other way around to get an idea of the values you want).
Wed Dec 03 2008, 02:50PM
I'm a big supporter of optical detectors, rather than mechanical. The problem is that we want to get microsecond timing out of it, but mechanical systems are generally more on millisecond levels. For example, that's one reason we use SCR's instead of relays.
Of course repeatability is the main issue; as long as it's reasonably fast and any built-in delay is absolutely constant from shot to shot, then you can always adjust the distance to the coil to compensate for the delay.
Cheers, Barry
What do elves learn in 1st grade? The elf-abet
Killa-X
Wed Dec 03 2008, 08:33PM
Yeah, The first I heard of optical sensors, I was thinking it could be too slow, like a possible delay, also "outside world" lighting might effect.
So like, whats the real design here. A Light sensor (photocell?) and a LED? So when the light is on fully, it has less resistance on the 9V output so it triggers a SCR..? Because I know in mechanical, you dont want the "bullet" to be a spark-gap ignite. You want it to trigger a SCR..
Other than that, I guess with most I seen online, people tend to either have almost similar coil sizes, or 1 big and 1 small..The small usually being the primary.
rp181
Wed Dec 03 2008, 09:40PM
A photo transistor with IR LED works great. A LM339 comparator is good to trigger.
KLH
Thu Dec 04 2008, 07:04PM
Killa-X wrote ...
Like rp181 said, you should use a phototransistor (or a photodiode). A photocell is simply too slow, especially when you build higher power, higher speed coilguns. A phototransistor should be fast enough for most applications, but the fastest coilguns will need the even-faster photodiode.
Phototransistors can also be used almost exactly like photocells. Photodiodes need a current-to-voltage amplifier with high gain (since photodiodes act like current sources).
To trigger the SCR, record the voltage from the phototransistor/diode when the projectile is between the sensor set and use that voltage to trigger a comparator.
big5824
Thu Dec 04 2008, 09:21PM
what about an LDR? would that switch fast enough?
rp181
Fri Dec 05 2008, 01:02AM
LDR's are slower than transistors. Heres a schematic i made for triggering, that is attached to a delay circuit which you can adjust for best performance (via changing capacitors and resistors). I havnt tested it yet though.
It's on the bottom of the page.
youngcoilgunner
Fri Dec 05 2008, 04:51AM
youngcoilgunner Registered Member #1633 Joined: Tue Aug 12 2008, 04:21AM
dude, thats one heck of a schematic.
