  • Guests: 45
why not use spst switches on single stage coilguns?
casey
Sun Nov 16 2008, 04:29AM Print
casey Registered Member #1787 Joined: Thu Oct 30 2008, 12:33AM
ok, i've been looking around and can't find the answer. why do most people use scr's or igbt's for switches in their coilguns. why not just use a spst switch? or is it more efficient to use the other switches. i got some scr's just don't see why.
teslacoolguy
Sun Nov 16 2008, 04:45AM
spst switches are made for small currents and the small contacts will weld together with just a small photoflash cap. Scr's have a high pulse rating and they can take the pulse from the cap bank. a small stud scr usually has around a 800-1000A pulse rating and as discharge time decreases that rating goes up exponentally.
Backyard Skunkworks
Sun Nov 16 2008, 06:08AM
Very large fast closing switches can work up to a few hundred joules. TCG is right that normal sized switches will just weld, and this welding takes up a lot of the energy that was supposed to be used to move the projectile.
If you can get a switch to close without any major sparking, it will work fine. This is far easier said than done when your dealing with capacitor banks.
big5824
Sun Nov 16 2008, 10:25AM
yea, if theres sparks then its wasting a lotttt of energy
On my gun, i was getting 0.25% efficiency before my scr arrived (i was just touching the coil wire onto the caps)
After i got the scr installed, it increased to around 1.5%, so it makes a big difference
