  • Guests: 37
Boost converter inductor
Camel
Wed Nov 12 2008, 08:00AM Print
Camel Registered Member #1694 Joined: Sat Sept 13 2008, 09:13AM
Hi,
I'm making a boost converter similar to this one
Since I can't find any high current inductors of around that value, I've decided to buy myself a ferrite bar and some 22guage wire so I can make one myself. My question is, how many turns will I need for approximately 130mH?? Does anyone know of a chart or something? I've tried googling to no avail.
Gratitude
Wed Nov 12 2008, 10:20AM
Gratitude Registered Member #1702 Joined: Wed Sept 17 2008, 10:14PM
i think it sgoing to be usefull for you
22AWG, 30 turns, 3 layers
core: Ferrite
*0.5 inch diameter
*1.0 lengthe
Dr. Slack
Wed Nov 12 2008, 10:22AM
With a homogeneuos core there are very good formulae. All air you can ue Wheeler's. All ferrite is even easier, you can do it from first principles. With a mixed magnetic circuit of ferrite in the middle + air return, you may or may not find tables for your exact geometry, and you may or may not want to do the voume integration to get there from first principles. The very long air return means the effective permeability will be closer to air, say ur like 2-5 range, so use wheelers with that and it will get you in the ball-park. Resonate the inductor with a known capacitor to get the exact value, then iterate.
Camel
Wed Nov 12 2008, 11:35AM
Gratitude, I tried your suggestion. With 5V in, I was getting over 2kV out!! Can't say for sure what voltage out was because my multimeter only goes up to 2kV.
I think I'll stick with this inductor for now :D
