  • Guests: 62
Photo Interrupters
guitarlord66
Sat Nov 08 2008, 06:40AM Print
guitarlord66 Registered Member #1805 Joined: Sat Nov 08 2008, 06:29AM
Hi,
I have built numerous single stage Coil Guns from used disposable camera's and I want to try and build a multistage one. I found a schematic for a photo interrupter circuit that activates a relay, but it runs on 12v and I would like to use 9v.
PhotoInterrupterCircuit
Will this circuit work for what I'm wanting to do?
Do I have to change any resisters or anything to make it work at 9v?
Any help will be very much appreciated.
phibes
Sat Nov 08 2008, 08:15AM
phibes Registered Member #571 Joined: Thu Mar 08 2007, 12:48AM
To be honest, you may want to avoid any circuit that involves a relay as your switch. It's slow, and won't allow enough current to flow through to make a worthwhile accelerator.
guitarlord66
Sat Nov 08 2008, 08:57AM
Oh... All of the Coil Guns Ive made so far use relays to switch.
Killa-X
Sat Nov 08 2008, 03:25PM
I use SCR. As long as they are rated for the power you will be using they are good. This way a 9V battery triggers it one time, and it lets all current flow until its under X volts. mines like a 500V 50A surge rating, and rated for 800V 50Amps. I got 2 so I can do a multi stage :D
Backyard Skunkworks
Sun Nov 09 2008, 03:44AM
Switching methods really depend on bank energy.
Under 100J you can always get by with a mechanical switch, although relays are slow to close if your attempting to time the current flow. Relays should always take around the same time to close though, so you can build the delay into the design and placement of the interrupter.
Banks up to around 1kJ can be switched with spring loaded contacts or an SCR, an SCR is the only option past about 1kJ. Unless your talking about several kJ, in which case you'll need a trigatron.
guitarlord66
Sun Nov 09 2008, 03:52AM
Thanks for all the help.
I think Ive worked out my problem about the 12v. I'll just hook together 2 AA or AAA and a 9v battery to get the 12v. Will this work though? I tried it and tested with my multimeter and it worked but will it do anything over time?
For the relay issue I'm only working with disposable camera caps and chargers so I think a relay will work, its worked so far.
I did look at SCR's but I didn't really understand how they worked it seemed to me that they only work with a set voltage but I want to be able to try more or less capacitors.
Any more opinions or help will still be very much appreciated.
Backyard Skunkworks
Sun Nov 09 2008, 04:04AM
Do not try using disposable camera caps in series. They will die young, and potentially explode. Getting 12V from a 9V battery and two AAAs can work, although its not ideal.
How to trigger an SCR Link2
You can use an SCR at whatever voltage you like, up to its rating.
We can tell you a bit more about deign if you give us a rough idea of how many flash caps you intend to use.
teslacoolguy
Sun Nov 09 2008, 04:17AM
Backyard Skunkworks wrote ...
Not really. I have a photoflash cap bank with 8 strings of 6 capacitors and i charge it up to around 1.8kv and i have yet to have one die on me. Maybe that is because i am using proper balance resistors and a protection diode?
Backyard Skunkworks
Sun Nov 09 2008, 04:31AM
teslacoolguy wrote ...
Quite possible. cheesey
guitarlord66
Sun Nov 09 2008, 04:32AM
I'm not sure on how many caps or chargers I'm going to use and to what voltage the caps will be charged to. That's why I like relays because they just work at any voltage (until they weld together but I haven't had that happen yet), but SCR's look like voltage and capacitance need to be set.
If I'm wrong please correct me.
