  • Guests: 60
barrel thickness
casey
Thu Oct 30 2008, 12:42AM Print
casey Registered Member #1787 Joined: Thu Oct 30 2008, 12:33AM
how much of an affect does the barrel thickness have? i have a tube with 1/4" ID and 3/8" OD. and another with 3/8" ID and 1/2" OD. should the walls be as thin as possible for best performance?
guitardude012
Thu Oct 30 2008, 01:53AM
guitardude012 Registered Member #968 Joined: Fri Aug 24 2007, 04:54PM
Barrel thickness is important, it should be as thin as possible. Ideally you wouldn't even have a barrel(I have seen coilguns without one) but you should try for the thinnest barrel that won't crush around the projectile.
1/8" is pretty thick for the wall. What material are you using? I have had good luck with polycarbonate. It has the advantage of being clear if you are trying to time the projectile through the barrel.
rp181
Thu Oct 30 2008, 02:11AM
On barry's website, he did some FEMM simulations, and it showed that it doesnt affect it much, i can agree based on expierence. I this it is because the magnetic field lines intersect, so it wont affect it much.
Backyard Skunkworks
Thu Oct 30 2008, 02:23AM
The 1/4ID 3/8OD one has 1/16th wall, which will work alright. The barrel-less option involves encasing the coil in a strong glue, to keep them from constricting in on the projectile when fired. If you use thick enough wire, you might even get away with a glue-free barrel-less coi unless you use too much power.
