  • Guests: 49
More power coil gun
Dragon64
Fri Oct 10 2008, 04:21AM Print
Dragon64 Registered Member #1438 Joined: Sat Apr 12 2008, 12:57AM
Well I am planning to build a more powerful coil gun then I made before.
Since PE= (1/2)(C)(V)^2
Would one of my 470uF 200V capacitor store up to 94 joules?
So if I had 10 of those capacitors hooked in parallel, I would get a 940 joule (0.94 KJ) capacitor bank when fully charged?
How powerful would it be able to project a toothpick sized nail at maximum charge?
OZZY
Fri Oct 10 2008, 12:44PM
OZZY Registered Member #511 Joined: Sat Feb 10 2007, 11:36AM
Hi hydraliskdragon
470uF at 200V is 9.4J. You may want bigger capacitors! If you intend to use a small nail as the projectile then I would recommend no more than 100J per stage.
Ozzy
Dragon64
Fri Oct 10 2008, 01:08PM
Eek, miss calculation.
I was wondering why I was getting huge amount of energy for such a small capacitor.
Bjørn
Fri Oct 10 2008, 02:59PM
Find the mass of your projectile and see how fast it will move if you manage to put 10% of the capacitor energy into it. (e = 0.5*m*(v^2), solve for v) That is the upper limit of what you can expect if you do everything right.
In reality a fast moving projectile makes it difficult to reach 10% efficiency and you should expect a significantly lower velocity for small projectiles.
rp181
Fri Oct 10 2008, 10:06PM
keep in mind that the projectile will saturate.
Dragon64
Sat Oct 11 2008, 02:40AM
Well, after finding out that my capacitor didn't store enough PE to make any real powerful coil gun.
What would be a good source for salvaging good capacitor with high Farad and Voltage? Excluding computers due to hard to obtain reason's.
Quantum Singularity
Sat Oct 11 2008, 06:30AM
Ebay is the typical source. For really big caps I have found some at hamfests as well, not sure if you have anything like that up there.
Killa-X
Sat Oct 25 2008, 04:15AM
I have 400V 470uf capacitors. One guy on instructables, used only 1 of these, and a 22 AWG, 12 layer coil 30mm wide, over a straw. It fires a metal 1 inch piece through a coffee can. Claims it has 6% efficiency. Each is .. 36.7 or 37.6 joules. I forgot which one :( If your interested, they still sell them.
I think i got my 1000V 6Amp diodes there too :)
Camel
Sat Oct 25 2008, 10:09AM
Camel Registered Member #1694 Joined: Sat Sept 13 2008, 09:13AM
E = 0.5xCxV^2
Thats the formula for finding the energy a capacitor could store. C is capacitance in farads, V is voltage you plan on charging your caps to.
Bamacoiler
Sat Oct 25 2008, 11:18AM
Bamacoiler Registered Member #1628 Joined: Wed Aug 06 2008, 08:48PM
I have 30, 7700mfd 200v electrolytic capacitors for sale in the sale and trade.
Garry Neeley
