  • Guests: 67
having a problem with coilgun
rp181
Fri Oct 10 2008, 12:07AM Print
My circuit is as follows:
coil is connected to diode parrallel with it. The cathode of the diode is connected to the cathode of the SCR. The anode of the SCR is connecting to the capacitor, and the cathode of the capacitor connected to the cathode anode of the diode.
When i try to charge the cap, it shorts throught the SCR. When the SCR is un connected, it doesnt conduct. But oncei put the capacitor in, it shorts right through the SCR.
In addition, My voltage quadroupler was plugged in, and connected to the cap. The voltage quadroupler capacitor blew, spewing electrolytic vapor. Why did this happen?
rp181
Fri Oct 10 2008, 01:46AM
Bad news. I disconnected the SCR's compleatly, and tested them. One of them is conducting both ways with no gate signal. The other two are fine. How is it possiable it burned? An anti-parrallel diode was in place, and i only used one capacitor. Is there any other way this could have happned, like EM field?
guitardude012
Fri Oct 10 2008, 08:28PM
guitardude012 Registered Member #968 Joined: Fri Aug 24 2007, 04:54PM
What gate voltage, current, and on time?
rp181
Fri Oct 10 2008, 08:37PM
nothing, never gave power to gate.
EDIT: i just tried again, with 1 of the working SCR's and a set of 2 capacitors in parrallel. While i was charging the capacitors, it got to 160, and with no gate signal, it suddenly discharged through the SCR. This keeps happening. When i disconnect the SCR, the SCR works fine. Is it possible that the leakage current is enough to trigger it?
Circuit:
ThThpix
EDIT EDIT: It occured to me that it could be maximum rate of voltage rise. The datasheet says its 500v/us. Do you think its feasible that mains can do that?
rp181
Sat Oct 11 2008, 05:44PM
Well, i ballasted mains with a 200ohm resistor bank, and the SCR didn't short! The problem was dv/dt.
