  • Guests: 40
voltage converter 4.5 volt to 900 volt question
voyagerscout
Thu Sept 25 2008, 06:16PM Print
voyagerscout Registered Member #1696 Joined: Sat Sept 13 2008, 06:01PM
I took a voltage converter from a disposable camera circuit, and modified it.
I tripled the input voltage, so the output voltage is 990V, and hooked up a amp-meter in series with the the caps I'm charging.
a 180 mA output, that's about 178 watt :S
that can't be right....
what am I doing wrong?
Bamacoiler
Thu Sept 25 2008, 07:43PM
Bamacoiler Registered Member #1628 Joined: Wed Aug 06 2008, 08:48PM
What kind of meter are you using to measure current?
Bamacoiler
Moderator: Please delete. Double post was an accident.
Shaun
Thu Sept 25 2008, 09:34PM
While charging a capacitor the voltage will be much less than 990, because it will drop under load, and the current will vary too quickly for a multimeter to read.
The best way to measure output power is to time how long it takes to charge a capacitor of known energy. For example, if it takes 30 seconds to charge a 180J capacitor, you are getting 6W of output power.
