  • Guests: 44
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Average efficiency
NiG
Sun Sept 21 2008, 12:17PM Print
NiG Registered Member #1372 Joined: Tue Mar 04 2008, 12:16AM
Just a quick question. How much is the average efficiency you can obtain ?
Now I have a coilgun that can feature 2.6J with an efficiency of 2.5%. However, my goal is to go over that result, since I want at least an efficiency of 3%.
bye
Sun Sept 21 2008, 01:24PM
3% is a good goal, and is pretty average. There are systems out there capable of up to 10%, but as a rule, they require some careful design.
Dave
Sun Sept 21 2008, 02:17PM
In my experience 2 - 3% is very good for coils in air.
If you haven't already, you'll want to tune your coilgun by taking careful measurements over a wide range of projectile lengths, voltages, and turns on the coil.
You might be able to get 5 - 8% efficiency by designing a coil with external iron to improve the magnetic flux path. This is fun -- in a small portable demonstrator I can charge and shoot directly from a 12v lantern battery.
Cheers, Barry
Every exit is an entrance to somewhere
Sun Sept 21 2008, 06:25PM
I got 2.65% peak with my 1st (430J) coil gun, but that wasn't while running with the maximum bank voltage.
FastMHz
Sun Sept 21 2008, 07:03PM
FastMHz Registered Member #179 Joined: Thu Feb 16 2006, 02:08AM
Location: Hagerstown, Maryland - Close to Prime Outlets
For induction launchers, I was getting near 10%:
Spreadsheet On This Page
I hope to do even better with my new 24kj system.
Quantum Singularity
Fri Sept 26 2008, 12:24AM
It seems induction launchers have the potential for greater efficiency compared to reluctance based coilguns. Unfortunately my website is down right now (no internet at my new house yet) but my first couple induction launchers were close to 10% as well, and had I been able to charge them fully I believe I could have hit that mark as their efficiency steadily went up with higher charges and the highest I've ever went is approximately 50% charge and if memory serves was around 8% in efficiency.
Fri Sept 26 2008, 01:19PM
The type of induction launchers that do so well are the ones built with a flat pancake coil and aluminum disk. They benefit from the very tight magnetic coupling of the close contact between coil and disk.
But! For obvious reasons, you only get one stage. There is no way to add stages for higher speeds, without changing to a colinear coil-around-the-outside design. (See PLIM, pulsed linear induction motor, like this one.) And some hobbyists early results with PLIM suggest lower efficiencies in the first stage.
Cheers, Barry
Sex is like math - add the bed, subtract the clothes, divide the legs ... and pray you don't multiply
Andyman
Fri Sept 26 2008, 05:46PM
What would be the best way to calculate efficiency? I never really tried before on my coils.
youngcoilgunner
Fri Sept 26 2008, 11:15PM
youngcoilgunner Registered Member #1633 Joined: Tue Aug 12 2008, 04:21AM
shoot a projectile out of your gun on a level surface, say 12'' above the ground. first measure the projectiles mass, and then charge your bank and shoot it. using this equation Eff = (1/2mv^2)/(1/2 cV^2), where v = velocity, m = mass of projectile in kg, c = capacitance in farads, V = voltage on bank. to find the velocity of the bullet, use x= vit +1/2at^2 to find the time it takes the projectile to drop 12", then use x/t =v to find velocity based on the distance your projectile traveled
