  • Guests: 77
The characteristics of a projectile made of permalloy
nicora
Wed Sept 10 2008, 03:24PM Print
nicora Registered Member #1681 Joined: Fri Sept 05 2008, 07:39PM
There are two kinds of permalloy.
One is 78.5%-Ni permalloy, and the other is 45%-Ni permalloy.
Are there some differences if I use these materials as a projectile?
And Are there some differences between a projectile made of Fe and of permalloy?
guitardude012
Wed Sept 10 2008, 03:31PM
guitardude012 Registered Member #968 Joined: Fri Aug 24 2007, 04:54PM
I believe 78.5% Ni permalloy has a higher max permeability but saturates faster.
I attempted to get some of this stuff this week and was unable.. Not only is it very expensive, but the forger I talked to could not produce it in small diameter because it is brittle(I requested 5/16").
He recommended another steel alloy for this use(ASTM A848) and I will have some at the end of the week. I will let you know how it goes.
rp181
Thu Sept 11 2008, 07:26PM
how bout Hymu-80?
nicora
Fri Sept 12 2008, 01:55PM
>quitardude012
If a projectile saturates completely, is there some problem?
Is it about hysteresis curve?
I think A848 behaves like permalloy.
I look forward to getting your reply. Good luck!
>rp181
Could you tell me the characteristics(especially permeability) of Hymu-80?
rp181
Fri Sept 12 2008, 09:26PM
really expensive though
nicora
Sat Sept 13 2008, 08:27AM
>rp181
Thank you.
I add Hymu-80 to the options.
But I doubt that I can buy the material in Japan.
I think that the more the permeability of a projectile increases, the more the efficiency of a coil-gun increases.
Is this right?
Sat Sept 13 2008, 02:00PM
nicora wrote ...
I think that the more the permeability of a projectile increases, the more the efficiency of a coil-gun increases. Is this right?
Yes, because a coilgun (like other dc motors) operates on the saliency ratio. That is, the ratio of maximum and minimum inductance. A higher permeability leads to a higher ratio of inductance.
On the other hand, the velocity decreases as the density of the projectile goes up. For maximum velocity a useful comparison between materials is the ratio of permeability to unit mass.
Note that efficiency is not affected by density, just velocity, because efficiency simply depends on the magnetic properties. So two otherwise-identical materials of different density will gain the same kinetic energy; but the heavier one will move slower in the relation KE=1/2 m v^2.
There's no place like 127.0.0.1
nicora
Sat Sept 13 2008, 03:24PM
>Barry
Thank you for your kind comments.
But I have a question still.
According to your ideas, if a permeability of a projectile increases unlimitedly, the velocity of the projectile increases unlimitedly.
So I think that there is a supremum(in other words, saturation value) if we use the law of energy conservation.
Is this way of thinking right?
rp181
Sat Sept 13 2008, 05:22PM
i emailed a company for a quote for a .5in dia x 1ft rod of hymu 80, ile tell you the cost.
nicora
Sat Sept 13 2008, 06:01PM
I see.
I will try to do it.
