  • Guests: 36
Voltage doubler
Camel
Sat Sept 20 2008, 03:27AM Print
Camel Registered Member #1694 Joined: Sat Sept 13 2008, 09:13AM
Hey all,
My caps have a working voltage of 400v. I am charging them with an inverter which puts out 230v AC then a voltage doubler. My voltage doubler puts out 560v DC when I measure it with my multimeter. My question is . . . HOW is that even possible?? And how can I restrict the output to 400v preferably without affecting the charge time? The person who says disconnect when the caps reach 400v gets a kick in the bum. tongue
youngcoilgunner
Sat Sept 20 2008, 03:32AM
youngcoilgunner Registered Member #1633 Joined: Tue Aug 12 2008, 04:21AM
Use a feedback system which stops the charging when it reaches 400. use a voltage divider to output around .6 volts to a 2n3904 and a small ceramic capacitor attached to ground, then use the 3904 to shut of power to the inverter. you could power a small relay with the 3904 which would disconnect power from the inverter
Camel
Sat Sept 20 2008, 05:08AM
Thanks mate.
I just charged my cap bank completely for the first time. It takes ages to reach 300v, and ages more to reach 350v. I think ill use your idea to turn on an LED once it reaches 350v. It would take years to go from 350 to past 400v.
Firefox
Sat Sept 20 2008, 05:15AM
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
What size caps are you using in your doubler? If they are small, your power input will be low, and so your charging speed will be slow too.
Camel
Sat Sept 20 2008, 05:19AM
They are 100uF caps. Do you reckon it would help if I put some in parallel?
Firefox
Sat Sept 20 2008, 07:29AM
Hmmm, no 100uF should be plenty. Infact, I think 100uF is too much for a 60Hz 20A breaker. Are you sure they arent 100nF?
How big are you load capacitors that you are charging?
Camel
Sat Sept 20 2008, 10:57AM
Nah man, they are electrolytics. I'm charging a 1000uF cap bank.
