  • Guests: 84
Best coil and fastest switching system for 8kJ
1 2 3 4
R.G
Sun Jul 27 2008, 12:36PM Print
R.G Registered Member #1608 Joined: Sun Jul 27 2008, 12:20PM
Hi, all!
I want to build a multi stage coilgun using an 8kJ capacitor bank, but I wanna know 2 things:
The best kind of coil: wire thickness, number of windings.
and the best switching system for the coils.
Sun Jul 27 2008, 02:47PM
The "best coil" is the one that delivers the most amount of energy in the right amount of time. This depends on factors such as inside diameter, length and desired inductance.
It really really helps to first choose the dimensions of the object you want to shoot. From this, you'll have a good idea of the coil's length and inside diameter.
I recommend a coil of two layers of windings, or three layers at the most. That is, a coil with low winding height will work better than thick coils that end up with a lot of wire farther away from the projectile. My experience has been that thin coils with thick wire will work better than others.
As for the desired inductance, that depends on each stage's capacitance value and the time you want the pulse to last. This is a little engineering puzzle for which you can tinker with an RLC simulator, an LC time table, and an inductor design calculator.
Good luck and have fun! ~~Barry~~
teslacoolguy
Sun Jul 27 2008, 02:50PM
8KJ is a LOT of power to be switching. You would be better off building a much smaller seperate cap bank for each stage switched by a scr. For the coil, it depends on how much power you are switching. A 400j bank (per stage) you would need 20g wire. A 300j bank you will need 22g wire, for a 250j bank you can use 24g wire and so on. The number of windings varys significantly with the projectile, weight of the projectile, barrell, and so on but generally you will need around 300 turns per stage.
rp181
Sun Jul 27 2008, 03:23PM
i think he meant 8kj total energy, have you got a switch yet?
tesla:
you said 400J with 20G wire, but i would go with thicher, 10-15g
R.G
Sun Jul 27 2008, 05:54PM
Indeed, I ment 8kJ TOTAL energy, rp.
And no, I don't have a switch yet, because I yet have to figure out the fastest switcher for these high current's.
rp181
Sun Jul 27 2008, 07:41PM
how many stages?
SCR's are the way to go to switch.
Dr. SSTC
Mon Jul 28 2008, 08:01AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
teslacoolguy wrote ...
300 per stage? i thought you have to decrease number of turns for every stage for the speed to build up
R.G
Wed Jul 30 2008, 08:24PM
It's a 6 stage coilgun, the attachment is the final design (it's NOT my design)
1217449423 1608 FT50844 Stalker Gauss Rifle
teslacoolguy
Wed Jul 30 2008, 11:34PM
How exactly are you going to fit 8kj into that thing neutral ? Nice gun though.
rp181
Thu Jul 31 2008, 02:41AM
you could have caps in a backpack =/
