  • Guests: 426
GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
DRSSTC
1 2 3 4  last
KresoLiubov
Tue Jun 17 2008, 03:29PM Print
KresoLiubov Registered Member #1153 Joined: Mon Dec 03 2007, 07:27PM
Last update: 27 / 10 / 2008
So after bunch of SGTC-s and whole bunch more of SSTC-s, it is time for a first DRSSTC!
I will write all costs if in case somebody wants to replicate project or simply if anybody here is interested in the project.
I removed the "steps" because it was confusing. Im just writing a total until now:
Invested until now : 3200,00 $
*(1) Cost of MMC is same like in original but i will instead use 12 capacitors CD9420C20P15K. Simply i don't want to use a fan to cool down capacitor and want to add little bit more reliability.
*(2) The total of digikey would be little smaller but i ordered some simple things like IC-s by triple just in case some components let the magic smoke out. But its maximally 5-10 $ difference. However they was out of stock on TVS and some more little things so in final it would be more or less same!
*(3) Thankfully to Steve Ward i have a bridge capacitor. Thanks Steve!
*(4) Thankfully to teslacoolguy i have a MMC. Thanks teslacoolguy!
________________________
Pictures
______________ __________
I got the fan for case today, i think it will suit to plexy base. Here is actual photo of it:
Th
My friend winded the transformer for me. HV insulating sheet between every layer, vacuum potted in shellac. I'm just calculating and im sure a 48 VA is a overkill! And since i want my coil to be light as possible i will order another 25 VA. Oh and funny thing is that i have Chinese step down inverter 220-110 VAC 300 VA on same type of core confused . Croatian quality xformer photo:
Th
I have decided that this transformer is and overkill definitely. So i ordered a 25 VA toroidal transformer. I also asked them not to put thermal fuse or any kind of protections thy regularly put in the core. We don't want such fuse open in middle of DRSSTC operation.
The new transformer arrived just today:
Th
Here is the current heat sink i plan to use. However its just thinking because i don't have the actual boards still. I want my setup to be light so i will use a small value temperature shutdown setup and a smaller heat sink with a high power papst fan. Im sure it will not overheat. I just need to get the boards to see what can i push there:
Th
I decided not to use this one because it dissipates too little heat. I decided to to use tower copper heat sink or sintered heat pipe nitrogon type.
Here is first heatsink to be used
Th
Th
Or this one :
Th
Th
I will machine bigger copper bases for mounting IGBT-s
DRSSTC BASE
Construction will follow today, just need to cut the threads
Th
I decided not to use this base. The 5 mm plexy is to thin to support coil as need. I will use a 10 mm plexy.
Here is the new base:
Th
Its blue because its color of protective film, its crystal clear usually :)
And mounts for the fan that will cool everything in there generally.
Th
Built the base and thats all i can do because my boards didn't come yet. Strange parts ordered two weeks after them came on time.
Finished the base and mounted the fan:
Th
I think it will be pretty, if DRSSTC does not kill it rolleyes
Th
Looking how would heat sinks fit in there. And im surely going for nitrogon. The fan on this one gives enough airflow to cool down the IGBTS without even any heat sink
Th
This one does not look bad either but i made my choice. This one will stay for some other project (little bad photo here):
Th
Digikey order comes:
Th
Secondary:
Th
Current status:
Th
Th
Time to work on the heatsink:
First unsolder the original small copper base
Th
Then i got a big block of copper, put it in vice and started waving the hand saw like a lunatic ( i thought i will die before cutting this piece) for 1 hour and i get this:
Th
Then solder it to the heat pipes. Its was very hard because i don't have enough powerful blow torch:
Th
Then prepare it for painting:
Th
Then paint it and finished:
Th
Decided to change heat sink again!
Th
Th
Th
Made the primary supports:
Th
And the secondary end caps:
Th
Made the primary:
Th
First preliminary testing:
Th
Interrupter for "test" :
Th
No updates for long time. Since im moving to my house soon i packed many of things and simply my DRSSTC got pushed to a small bedroom until then, its not fun.
ThThpix
I started working on the interrupter. I don't have a casing for it so its "open" for now. In this country everything is strange so i needed to search 7 days for a DPDT switch for auto/normal and only then i found not exactly like needed. The white bloobs are silicone glue holding the leds on place.
ThThpix
This is finished interupter:
ThThpix
ThThpix
This is the cable i made for interupter:
ThThpix
Its dual clinch. The interrupter output is a male audio jack going in 2X cinch splitter (AUX mode and BURST/AUTO(SINGLE SHOT) and on the DRSSTC side there is a cinch to BNC converter which goes to BNC on board.
MMC, little bit made in a hurry
ThThpix
And toroid i made (until a spun toroid does not arrive)
ThThpix
Time to fire it! I first feed the coil from a Statron bench power supply. Everything was working fine, got a nice small discharge, tested all interrupter modes (and burst does not work, i will need to inspect it). After approximately 30 seconds BANG! The drsstc blew all 3 Statron channels. Then i feed it trough 2 small transformers 220 V to 12 and then 12 to 220 V and everything was fine. Time to connect it to the wall, no choice (i don't have a variac). Coil works fine but i didn't push it very far because:
1. Dont have strike rail
2. Dont have proper toroid (i get 6-14 sparks on all sides, not one long discharge)
However i have let it rip at maximum PW and PRF for 30 minutes and everything was ice cold, no problems at all. I have over current limit to 300 A and it is tripping all the time, however the LED current meter goes only to 100 A.
Time to finish just the small bits and move on to a bigger DRSSTC, after torturing this one as much i can :)
ThThpix
smile
Additional photos of the base at this moment. I need to think out how to shield everything in there now.
ThThpix
Here is few photos. Tonight i will take video. I made a bridge rectifier from some HUGE diodes and now its fine. Im torturing the coil in max PW and max PRF all the time, works wonderfully reliable.
ThThpix
ThThpix
ThThpix
Full power!
ThThpix
Photo of the day:
ThThpix
Youtube video: Link2
Ultra7
Tue Jun 17 2008, 08:02PM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
Sounds like you are building a Minibrute.
KresoLiubov
Wed Jun 18 2008, 04:30AM
Ultra7 wrote ...
Thats true. I decided to go this way because designing my board and everything else easily leads to potential problems and just carries more cost
Ultra7
Wed Jun 18 2008, 04:39PM
Be sure to visit Austin's thread "Experience with the Minibrute"
It is a wealth of knowledge, and saved me countless hours of pain to be able to have all the issues they found right there in one resource. Plus Austin and Wirenut have a very quick response time when asking them questions.
Dr. Shock is Dan, the writer and creator of the minibrute, and he also gets back to you with haste when asked questions.
Also, I'm almost done with my minibrute, and should have a nice vid to go with it once everything is together.
I'm just finishing up the advanced modulator, intend to have it done this weekend in fact.
Rest assured, you have "peoples" you can rely on when you get stuck.
KresoLiubov
Wed Jun 18 2008, 06:58PM
Thanks Ultra7,
i read that topic from first page to last, 2 times.
Im taking my time with this one to bring it to be beautiful and functional. Im waiting for shipment of boards now, still no answer from EVR, maybe they are out of stock.
I will ask if i come in problems surely, but thankfully i have all needed gadgets to debug it and helping people here smile
For now biggest problem is bridge capacitor. Until i receive all my stuff and book can you tell me dimensions of base for coil? I would like to give it to machining since it will take some time.
Dimensions that i need in photo
Th
Ultra7
Wed Jun 18 2008, 07:13PM
I'm not too keen on the metric system, I blame myself.
So the measurements are in inches.
the total dimensions are 12"L x 12"W 6"H/D for the entire bottom enclosure.
KresoLiubov
Thu Jun 19 2008, 05:06AM
Ultra7 wrote ...
Thank you. In case you will ever need 1 " is 2.54 centimeters and 100 cm is 1 meter
So dimensions are in metric:
30.48 cm L X 30.48 cm W X 15.24 cm H
And again thank you smile
Edit: I just found 2 new coolers in my drawer. I hope will they fit on board
Th
KresoLiubov
Thu Jun 19 2008, 04:35PM
I gave base to CNC machining.
The base plate will be cnc machined plexiglases with diamond polishing on end. The standoffs will be molded plexiglas. Pictures to come in 2 days. Added to cost
Mates
Thu Jun 19 2008, 05:19PM
KresoLiubov wrote ...
Th
I have found very simillar cooler recently in the old PC trash, do not have any use for it yet. These coolers look very sexy, however, is this "heat-pipes" technology really so good? I mean, the Cu plate which is in contact with the transistor is relatively thin and the connection to the heat-pipes involves very small area of the plate. Wouldn't it be better to have rather some kind of classics - a fat piece of AL (or ideally Cu) with few ribs ? Does anyone has any experience with this type of coolers?
Andyman
Thu Jun 19 2008, 05:53PM
If I remember correctly, large surface area dissipates heat much better than a large solid mass. The more fins there are, the better and if they are tiny, you can pack a lot more cooling fins in a small area. Small fins dissipate heat more quickly than larger fins.
I hope that makes sense angry
1 2 3 4  last
