  • Guests: 69
Multi Stage Coilgun
thecatisfat
Sat Jun 14 2008, 09:02PM Print
thecatisfat Registered Member #1542 Joined: Sat Jun 14 2008, 08:56PM
Well I've made a single stage coilgun with a 10,000 uF 200v capacitor and SCR and some other stuff. Now I would like to make a mutli stage coilgun. But I'm mot sure how to go about this. I thought of timing it or using a sensor to trigger the coils. Can someone please lead me in the right direction.
Hon1nbo
Sat Jun 14 2008, 09:45PM
using an optical sensor seems to be the best option, and they are very easy to use... they will trigger the proper SCR when the projectile has reached the proper distance from the next coil (if you use a small micro controller, you can experiment with delays and such to try to improve results rather than a strait up trigger.
thecatisfat
Sat Jun 14 2008, 11:09PM
OK cool.
so something like this would work?
Hon1nbo
Sun Jun 15 2008, 01:10AM
a little too small, what I would do is get some IR photodiodes and IR LEDs and just align them over each other in the barrel (may have to use a visible LED and a photoresistor if too much light can enter the barrel...)
thecatisfat
Sun Jun 15 2008, 02:47AM
I don't know much about optics and light. So you said that if disable light gets into the barrel that I shouldn't use IR. I'd like a sure firer method and I think that there is a good amount of light that gets into the barrel.
would this work:
