  • Guests: 72
Lyonel Baum (77)
Mattc1886 (17)
01/09 RickR (18)
01/09 TheBoozer (58)
01/09 invader (50)
Capacitors for capacitor bank
Dragon64
Wed Jun 04 2008, 03:26AM Print
Dragon64 Registered Member #1438 Joined: Sat Apr 12 2008, 12:57AM
Is making a capacitor bank using Car amp capacitors pracitical?
ea6b607
Wed Jun 04 2008, 03:38AM
ea6b607 Registered Member #1320 Joined: Sat Feb 16 2008, 01:31AM
not a good idea (assuming your using it for a electromagnetic accelerator). with low voltage (12vdc) you will require huge amounts huge amounts of current to transfer the energy and thus will need ridiculously sized wire. Also they actually are not cost effective even those big 3 farad caps only contain 216 joules of energy.
Backyard Skunkworks
Wed Jun 04 2008, 05:12AM
Not to mention that pulse discharges kill supercapacitors. You should either order some caps or use photoflash caps at a good margin below their voltage rating.
Andyman
Wed Jun 04 2008, 06:28AM
Also, with all that capacitance, it would take relatively forever to completely discharge, even if that is only 1/10 of a second.
Wed Jun 04 2008, 05:39PM
Andyman wrote ...
Yea, i have a big blue capacitor and it is like 60,000uf and it would not work on a coil gun because it would shoot the projectile forward and then suck it back due to there being a charge after it moved forward.
Well a good place to get some VERY cheap capacitors is alltronics.
These capacitors are only 7 bucks each, and for 2 capacitors my shipping price was like 6 bucks. They hold 312 joules each when fully charged. I bought two, they haven't arrived, but when they do i will let you know if they are quality.
