  • Guests: 71
33 J coilgun
High-Voltage
Tue May 13 2008, 07:39AM Print
High-Voltage Registered Member #1465 Joined: Sun May 04 2008, 10:41AM
Hey everyone. I built this one afternoon, it's quite crude :D
It currently uses 4 photoflash (all 330v) capacitors; 2x 160 uF and 2x 80uF all hooked in parallel. The bank stores 33 J of energy. The charging circuit is ripped directly from a flash camera and the trigger was a switch from an old washing machine I believe. It uses 1x AA battery takes 15-20s to charge and it can fire a one inch segment of nail that fits inside a drinking straw up to my ceiling from the ground. It's speed is not very fast probably not muchgreater than 10 m/s if that. smile If anyone has suggestions on how I could improve it's efficiency, it would be a great help.
- regards
1210663972 1465 FT0 Gauss Pistol
1210663972 1465 FT0 Guts
Solidacid
Tue May 13 2008, 08:53AM
Solidacid Registered Member #1430 Joined: Sun Apr 06 2008, 11:12AM
i don't get it. i tried building a coilgun with 1,2,4 and 8 photoflash capacitors and 5 different coils but i just cant get the projectile to fly furter than 2-3 meters.
flannelhead
Tue May 13 2008, 12:01PM
High-Voltage, that's certainly a very nice looking one smile
Solidacid, here are some reasons for poor efficiency in coilguns:
- Too many turns on the coil -> low peak current
- Projectile weight and starting place not optimal - this is the most important thing to experiment with
- Poor switch (use a SCR)
Take a look at Link2 for more information on tuning the gun.
I got a projectile of a few grams to fly about 10 metres with my 8 photoflash cap bank.
Solidacid
Tue May 13 2008, 09:46PM
how "strong" would the scr have to be? i can't get This kind of scr's, i can only get This and This kind.
awesome looking gun btw cheesey
rp181
Wed May 14 2008, 12:01AM
with only 33J, you only need a small SCR, the regular transistor looking one is fine.
will work, it has high enough ratings to expand your cap bank. Make sure you dont hard short the caps through this, and put a diode antiparrallel with the coil (to be on the safe side).
Solidacid
Wed May 14 2008, 08:23AM
would a "Thyristor 20A 800V TO220AB" work? if not, could i stack them?
