  • Guests: 58
questions regarding coilguns and railguns
ztrain
Wed Apr 30 2008, 08:14PM Print
ztrain Registered Member #1459 Joined: Wed Apr 30 2008, 08:06PM
hi, i would like to know what is beter a coil gun or a rail gun (or if one is beter at low voltage and the other at hi voltage) also how do you make a multi coiled coil gun (and get it timed right) im new to this so plz explane it like in an idiot.
Wed Apr 30 2008, 08:52PM
Better depends on what you want to achieve. A railgun will give a big noisy muzzle flash and send the projectile out with low efficiency, while a coil gun will shoot quietly and with somewhat higher efficiency. Voltage depends on component constraints, but given the nature of railguns I think high voltage would be preferable there. I've never built one though so it might not be necessary. For both coilguns and railguns voltages from 100 - 1000V are typically used. Successive coils in a multi-stage coilgun are trigger by sensing the projectile position or precise timing. An inductive sensor or photo-gate can be used for sensing.
ztrain
Thu May 01 2008, 10:59AM
ok ty.
Thu May 01 2008, 02:07PM
Here's one factor in your choice between railgun and coilgun...
Railgun construction requires some good fabrication skills and equipment, since you'll be striving for a very low ohmic resistance connection AND low friction through a sliding armature. It seems to me that railguns are more of a mechanical engineering feat than electrical engineering.
Coilguns are mechanically as simple as you can get. Everything in a coilgun is low-tolerance construction. A piece of iron of any shape will slide down a barrel of almost any size, inside a coil that can be randomly wound. Of course some sizes and shapes will work better than others but its construction is simple.
Cheers, Barry
What would the flying spaghetti monster do?
ztrain
Thu May 01 2008, 09:31PM
ok ty.... i actualy plan on going into macanical engineering. i just like high voltage stuf... idk why. there just fun (and dangerous)
