  • Guests: 55
need help with camera flash coil gun
Prutser
Sun Mar 09 2008, 03:05PM Print
Prutser Registered Member #1382 Joined: Sat Mar 08 2008, 09:04PM
Hi guys,
I read a lot of stuff about coil guns last days and diceded to give it a try..
I took the flash unit out of a disposable camera and it still worked out of the camera.
I removed the flash thing(lol) and i attached two wires on each side where the flash unit was.
But now when i hit the charge button it makes a stange bleeping noise and when i check the capacitor with my volt meter it is still empty :( And i cant figure out what's wrong
1205074955 1382 FT0 Total
1205074955 1382 FT0 Flash Unit
Sun Mar 09 2008, 03:59PM
The two pins you have connected is just 300v from the capacitor. The trigger is the third pin you in middle of the two others.
Here is what you need to do:
Connect the wires direct to the capacitor then place a switch between on of them. When the capacitor is fully charged press the switch to fire..
Then connect a freewheel diode between the capacitor to protect it against the spikes coming from the coil after the projectile is fireed. (It needs to be opposite from + and - so you don't short the circuit)
Prutser
Sun Mar 09 2008, 04:56PM
It worked!!! thank you very much!
Marble
Fri May 02 2008, 02:26AM
Marble Registered Member #640 Joined: Thu Apr 12 2007, 12:20AM
Hi can you please post a picture of what you have done to fix it? im a bit confused :(
