  • Guests: 32
Disc launcher questions
w1vlf
Mon Apr 07 2008, 06:53PM Print
w1vlf Registered Member #1329 Joined: Mon Feb 18 2008, 07:31PM
Hello Folks,
Today I started building a disc launcher. The coil is made of #12 wire and is the size of a CD rom disc in diameter.
It is only 1 wire thick at this point. The hole in the center is 3/8" in diameter.
The gorilla glue is almost done curing.
I spent a while on youtube and here looking at other folk's launchers.
Here is the question:
Why did I not see, or perhaps I missed it, that anyone has mounted their launcher onto a steel backing, for the bottom side??
Would that not concentrate the magnetic field on the topside of the disc and increase the efficiency?
Also give the coil a nice firm launching pad?
PauLC
W1VLF
Dr. Shark
Mon Apr 07 2008, 07:11PM
The reason is that a steel backing would lead to massive eddy current losses. Furthermore, depending on the pulse you deliver to the coil, the steel backing would probably be repelled from the coil and launch the coil itself into the air!
What people do is to place a steel rod through the center hole, which has to be laminated to avoid eddy currents, and this seems to help only in low power designs.
What you could do (and this has not been tried AFAIK) is to use a backing of ferrite ceramic, possibly a disk shaped ferrite magnet from an old speaker or from a microwave magnetron. Stick a ferrite rod through the center hole for added field focusing.
w1vlf
Mon Apr 07 2008, 07:27PM
Hello Dr Shark, Yes... I forgot about the Eddy currents... I always thought that Eddy currents were only generated in Non-ferrous materials.
YThe other thing that made me think of this idea was that some folks have used ferrous pipe around thier coilguns to improve efficiency.
This is my first attempt at the launcher.
Have you ever stacked several of these coils ???
PauLC
W1VLF
Dr. Shark
Mon Apr 07 2008, 08:32PM
If by stacking you mean putting several layers of winding in series or parallel, yes, people have done that. This way you can tweak your coil for more inductance (layers connected in series) or less resistance (layers in parallel).
If you are somehow hinting at an arrangement with several stages of acceleration, thats kinda impossible to do since the disk would have to pass through all the subsequent coils.
w1vlf
Mon Apr 07 2008, 11:32PM
Thanks again Shark, and yes I was thinking about the former. Also I would assume that the field increases with additional layers of coil?
If they are phased correctly??
Ijust launched my first aluminum disc!!!
WOW I was not ready for that
Havinf fun
PaulC
W1VLF
Quantum Singularity
Thu Apr 10 2008, 12:25AM
Depends on how the coils are connected. If they are wound in parallel the layers basically act as heavier wire, the number of turns stays the same. You should get a stronger pulse due to lesser resistance. I've wound a coil this way, two layers, and did get increased performance using the identical setup with single layer coil. Good luck with your project, disc launchers are a lot of fun (and of course be safe wink .
FastMHz
Wed Apr 30 2008, 05:56PM
FastMHz Registered Member #179 Joined: Thu Feb 16 2006, 02:08AM
Location: Hagerstown, Maryland - Close to Prime Outlets
More layers are good to a point...I found my 3-layer coil was less efficient than my two layer designs. I usually parallel the layers. I think the distance from the bottom layer to the projectile on top results in large magnetism losses.
