  • Guests: 21
  • Most ever online: 441
    Guests: 441, Members: 0 on 01 Oct : 16:32
TwirlyWhirly555 (33)
10/04 Michael W. (36)
10/05 GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
HV jet system
Mates
Tue Feb 26 2008, 12:41PM Print
Theoretical concept: An idea about high voltage jet system
While playing with my new CW multiplier Link2 I noticed that in case I’m close enough I can easily feel on my skin something like a strong wind coming from the positive electrode. This must be charged molecules of the air. Now I have an idea of building a jet device using this principle.
Do you people thing this could work?
Does somebody know whether similar devices with some practical use exist?
1204029644 1025 FT0 Jet
CompWiz
Tue Feb 26 2008, 02:42PM
CompWiz Registered Member #1038 Joined: Mon Oct 01 2007, 08:02PM
WOOT ion boosters!
Deep Space 1 uses this technology: Link2
Mates
Tue Feb 26 2008, 04:25PM
CompWiz wrote ...
WOOT ion boosters!
Thanks for the link...
You right. The principle is very simillar with the basic difference that I plan to use air and not xenon. Also, the used voltage is is much higher in my case. I'll probably give a try ... wink
Avi
Tue Feb 26 2008, 04:28PM
Does it mater that the final potential difference (on the right hand side) is in the opposite direction to all the others
teslacoolguy
Tue Feb 26 2008, 07:35PM
what are you going to use as a ground e.g. wire mesh?
Tue Feb 26 2008, 08:24PM
Mates wrote ...
This is an ion wind and "devices" using this principle are being built for a long time and they are called "lifters" wink
Andyman
Tue Feb 26 2008, 08:40PM
They're called lifters and they demonstrate the Biefeld-Brown effect. There is no actual "wind" or "air" moving because the lifters have been tested to function in an almost perfect vacuum.
[Edit: Link removed according to the rules Part II:I]
Bjørn
Tue Feb 26 2008, 09:16PM
I was one of the first on this forum to make a lifter and they generate a substancial flow of air. Please read some of the old threads to see the details of how the ions are created and move in the field.
The Biefeld-Brown "effect" is not an acceptable topic on this forum without hard proof (meaning better than this: Link2 ).
Spedy
Tue Feb 26 2008, 11:55PM
Spedy Registered Member #964 Joined: Wed Aug 22 2007, 12:39AM
Er, wouldn;t this be ruined by the thing where charge goes to the OUTSIDE of a conductor? Shouldn't there be be no charge be observable on the inside of those toroids and very little on the "top" and "bottom" surfaces (the near-flat faces around the holes")? I don;t see how with this the incoming air would charge...
Certainly an interesting concept you have there, it'd be cool to see it operate in open-air
Andyman
Wed Feb 27 2008, 01:06AM
Andyman wrote ...
Oh crap, I totally forgot about that. My apologies, please don't smite me! angry
Also I want to correct what I said. It wasn't a "lifter" that was tested in a vacuum. It was what's called an asymmetrical capacitor thruster that NASA tested in a vacuum and it was with only PARTIAL success. Lifters do only work in the air because of wind and air movement. I haven't looked into that stuff for a while and Bjørn's link was a little refresher for me.
Again, sorry about that breach of the rules.
Anyways, back on topic. Your idea is definitely a good one. Except I think that narrowing nozzle will decrease flow instead of increase it. The wind isn't strong enough to push through.
And I wonder if putting 3 electrodes at increasing tensions would act like an accelerator and get more wind than 3 at the same tension.
