  • Guests: 54
Levitator coil design
Thu Nov 09 2006, 03:40PM Print
I want to build a simple magnetic levitation device. It will work simple: You have an IR light beam, and feromagnetic object above it. When the object disrupts the light beam, a coil above the object is energized, attracts the object, the coil is deenergized, etc.etc... Looks simple, until it comes to the coil design. How does one determine the right amount of turns, wire gauge, coil shape, core material, core size etc..... ? Also what is the optimal driving voltage and frequency, assuming I will use tl494 to pwm the power switch?
thanks, J.M.
Thu Nov 09 2006, 08:19PM
You could check here for starters. Link2
and here Link2
When it comes to coil size you want as many turns as possible with as low resistance as possible. Therefor it depends on your coil voltage and the current flowing through it. As far as coil size goes a fatter one should work better than skinny. Frequency will depend on your coils strength and object being levitated. For the driving voltage you want as much current as possible through the coil, so it depends on the coil resistance, but 10 -20 volts is good.
I used 70 meters of 0,45 mm wire for my coil and the resistance was about 8 ohms, which is a little high. My coil gets hot at 12 volts after longer runs.
Good luck! cheesey
Sat Nov 11 2006, 12:11PM
ok thanks, I tried to wind a coil (10ohm, about 2x2cm), and it was getting super-hot (thats what I was afraid of) and with iron bolt as core it couldn't lift anything further than about 3mm from the bolt, so I probably need to wind a new monster-sized coil. Or are there any tricks to make it run cooler?
edit> I think I have an idea how to cheat- use a permanent magnet to "help" the coil and put another permanent magnet on the levitated object so they attract each other, now you need much less power to the coil, but I think that stability will be a problem.
edit2> yeah, a permanent magnet on the leitated object greatly increases attraction distance, and the difference between coil-on ond coil-off is still big :)
one more edit smile : I bought one IR diode and one IR phototransistor. They look the same, except one is clear and the other has gray-green dark tint. Does anybody have an idea which is which tongue ?
cjk2
Sat Nov 11 2006, 03:08PM
A 2x2cm square coil is probably too small, mine is like 4x4cm. I'm not sure what AWG wire you are using, but I used 18 AWG, which is probably too big.
I think stability will be a problem in your design, because your rig will only have two states, right?(On and off) I found that I even needed a lead compensation circuit, and my design is actually feedback based.
As for the IR diode/transistor pair, the one with the dark green tint Should be the transistor. I think they make the epoxy around it a color that filters out visible light so that the transistor only responds to the matching IR LED.
