  • Guests: 28
12/23 David (39)
12/25 Kolas (18)
will will voltage divider for DC DMM work with AC?
lokeycmos
Sun Sept 23 2012, 05:05PM Print
lokeycmos Registered Member #2553 Joined: Fri Dec 18 2009, 01:36PM
thanks to forum members i have the math to make a 100:1 voltage divider to extend the range of my DC DMM. my question is, will this resistive divider work equally well to measure AC? if it doesnt, how and what do i have to modify to make it accurately measure AC as well as DC. thank you in advance!
Sun Sept 23 2012, 07:00PM
Short answer = NO
Long anwser = Definate No
why? stray factors like capacitence, inductance and non-linear field distrubution along the length of the resistor, i dont think any simple mod will work or is known for this purpose.
From my experience your better off buying one of EVR's HF, HV probes for 500 USD, or the tek HVprobe for 900-1200 USD... it took me 3+ years to figure out how to make my HV probe, i quote my self :
[Begin Quote]
I have authored more threads on this matter than i can count.... search under my name. High Voltage and project Forums.
1347773476 2431 FT1630 Sam 0250a
1347773476 2431 FT1630 Sam 0249b
1347773476 2431 FT1630 Sam 0247c
The tek probe and mine side by side...
EDIT: here's some:
Link2 (HV measurement)
Link2 (Pots and HV measurements)
Link2 (cap 10,000:1)
Link2 (Etching)
Link2 (NST HV measurement)
Link2 (HV Diode making)
Link2 (Mearsuring HV resistor to high accurracy)
Link2 (HV resistors, Project)
[End Quote]
Mon Sept 24 2012, 09:12AM
Did you ever get that probe working properly Patrick? tongue
Mon Sept 24 2012, 12:36PM
YES at low frequencies
NO at high frequencies
The question is...when does low frequency become high frequency?
IF you only want to measure 50 or 60 Hz ac then you can calibrate your probe at that single frequency
RF and probably higher frequency audio will not give a correct reading due to various stray capacitances as mentioned above
also the voltage rating would have to be reduced with increasing frequency above some particular frequency.
To measure hf ac a capacitive divider is required ...... e.g. 1pF:1nF = x1000 probe.
Good eht probes are resistive at low frequency and capacitive at high frequency with careful compensation required at the transition.
Mon Sept 24 2012, 01:24PM
Patrick wrote ...
Short answer = NO
[Begin Quote]
EDIT: here's some:
Link2 (Etching)
[End Quote]
Not so fast.
You first need to ask the question, what do you mean by AC? What frequency?
If you are measuring just 60Hz high voltage line frequency, then ABSOLUTELY YES.
However, if you are looking to measure something of higher frequency, then maybe yes, maybe no. It all depends on what frequency and what accuracy (bandwidth) you are lookinig to measure.
lokeycmos
Mon Sept 24 2012, 02:08PM
thanks for all your replies! yes, it is only for 60Hz
Mon Sept 24 2012, 04:28PM
Heres the reason why i said no, i address this to both EVR and Sulaiman. I had in the early 2000's a 1 gig and 2 gig resistive divider, both for 20kV, made by me. they both read 30 to 45 kv, from a NST of 12kV rms, 60Hz, further more it would slowly change from 20kV on the didgital meter to 45 kV in about 7-10 seconds, then in 7-10 seconds it would oscillate down...
I wonder if the huge inductance and light stray capacitance conspire with 1Giga ohm to make a ringing up oscillation type system...(RCL)
Therfore even at 60 Hz (depending on what hes measureing) might not be useful.
I suppose the point " when does AC become HF AC?" is a valid point from Sulaiman.
Steve Conner wrote ...
Short Answer : I think so
long answer : Im plannnig a 1kv square wave generator with a high rate of rise and fall.... to verify the capabilities of my probe...
Ash Small
Mon Sept 24 2012, 05:21PM
I was going to suggest a string of fast diodes charging a string of capacitors through a string of resistors, to avoid any resonance effects. Are there any reasons why this wouldn't work, assuming the diodes were fast enough for the frequency being measured?
(you'd then measure the voltage accross one capacitor, using the DC DMM, and do the maths for RMS, etc. I can draw a shematic if requred.)
Tue Sept 25 2012, 02:46AM
Ash Small wrote ...
of all methods available, yours is the only one within his means, that would really work...
EDIT: Im thinking of measuring a color television at the red suction cup, thats pulsing DC right?
Ash Small
Tue Sept 25 2012, 08:42AM
Patrick wrote ...
It is, but if it is still connected to the screen, the screen is a capacitor, so is at a fairly steady voltage.
Early colour TV's had a 'tripler' circuit which also rectified the output of the flyback (LOPT), but all 'recent' colour CRT TV's have DC flybacks, but they can output AC if the diode has failed.
