  • Guests: 75
Bosko (56)
hen918 (30)
Yuri_Ivanov (35)
SoldierOhm (37)
01/01 Bosko (56)
01/01 hen918 (30)
01/01 Yuri_Ivanov (35)
My ΓK-71 (GK-71) HFVTTC
Sat Jul 21 2012, 09:12PM Print
GK-71 HFVTTC Project
Hey all,
This is my project thread for a High Frequency Vacuum Tube Tesla Coil using the russian GK-71 power pentode. It is based on RateReducer's Coil. I will try to build the same circuit but in a neater manner for a better look and longer runtimes.
Description :
  • Frequency is around 20-30MHz
  • Anode, feedback and ground connection are made of 10mm x 1mm section flat copper foil for higher current
  • Resonator and choke coils are wound on the same coilform with Ø2mm enameled copper wire
  • Coilform is a Ø50 ceramic tube to withstand the heat
  • I found nice chinese ceramic sockets for the GK-71 on Ebay, they look way better than russian bakelite ones.
  • HV power supply is an arrangement of two MOT's with voltage doublers connected in parallel, and primaries in series 180° out of phase for full wave rectification and 230V operation. Thanks Steve Conner for the suggestion smile
  • EMI/RFI filter + Variac on mains side
  • I expect a 30cm high silent flame output
  • GK-71 datasheet
I'm awaiting for the following parts :
  • Ceramic tube socket - received on 27/07
  • 1mm copper foil - received on 24/07
  • Filament transformer (20V-100VA)
  • 500W Wirewound Power Resistor for the ceramic coilform - received on 01/08
Question, comments and suggestions are welcomed smile
Schematic :
Schema11
GK-71 Tube :
71s10
HV Power Supply parts :
Hvpowe11
Changelog
Sun Jul 22 2012, 01:13AM
Will the DC blocking capacitor on the grid connection marked "optional" to be used? Without it any flashover on the feedback electrode has a high chance of ruining the tube.
Also, a DC blocking capacitor between the anode of the tube and the resonator. Otherwise, any ground strike will also have a chance of shorting out the power supply to ground and poses an even larger electrocution risk.
Aside from that, great documentation. Keep it up. Such coils are fun to play with.
Sun Jul 22 2012, 04:07AM
Thanks Weston for your kind help and encouragement smile
Well yes I will put the "optional" capacitor in the feedback circuit, doesn't hurts :)
About the DC blocking cap between plate and resonator, I understand it would be safer. But wouldn't that reduce the coil performance ? I mean I haven't seen any of those HF coils designed for big flame output have such a capacitor. Wouldn't it require a special capacitor with high power at high frequency capabilities ? Also it seems these coils do not tend to arc to ground, probly because of the plasma heat that keeps the flame growing upwards.
Hmm... I have two big 300pF 15kV ceramic capacitors rated for 30 kVA (kvar ?) Would it fit for this ?
Imag0812
Sun Jul 22 2012, 06:09AM
The DC blocking capacitor should have a minor impact on performance. The capacitance should have a very low reactance at operational frequency, and at that point it is only presenting parasitics. Both the ESL and ESR of doorknob caps are very low and you should not even need ones with a KVAR rating.
Just on a side note, I would trust surplus Russian doorknob caps more than the Chinese ones that you have, and they are usually cheaper too. However, the ones you have should do fine on in your application.
Do you plan on trying to add capacitance between anode and ground to optimize the coil? It forms part of the impedance matching circuit and can help achieve proper loading on the tube.
Sun Jul 22 2012, 07:46AM
Ok lol, I thought the chinese cap would be better because it's a lot bigger (maybe because it looks nice too) tongue
Well I also have some of these russian surplus caps, KVI-3 and K15Y-1 series, 470pF, 680pF and 1nF. (The K15Y-1's are indeed rated 40 KVAR!)
How do you calculate the optimal value of this cap you suggest to add between anode and ground ?
Sorry if this seems noob question, but tbh I'm new to this great hobby (this will be my 2nd coil), and for now I'm rather trying to reproduce others great coil as close as possible and get same results.
So I will first try to get the same (or close) output as RateReducer (40cm high silent flame) with the same build. (I will just add the feedback circuit capacitor).
Once I get this done, I will try to add all suggested improvments, one by one, in order to see how they each affect the output.
I found a russian schematic for a GU-50 that shows two additional caps :
- the left one is probly just an RF bypass cap, but is it necessary as we have the choke to block RF ?
- a 100nF between G2 and ground, what is it's purpose ?
Schema12
Oh btw, I have a weird doubt about my HV Power Supply circuit, but I posted it as a separate thread here: Link2
Thanks again for your kind help :)
PS: I could easily find all the needed documentations and detailed explanations about SGTC's, VTTC's, SSTC's, DRSSTC's operation. But I couldn't find any complete and detailed explanation of this base fed HF coil circuit... I had to gather little parts from here and there, mostly from russians and germans sites, and try to put them all together. If anyone has some good link explaining in details this circuit theory and operation it would be greatly appreciated ! Thanks smile
zrg
Sun Jul 22 2012, 04:41PM
zrg Registered Member #4762 Joined: Sun May 06 2012, 05:59PM
The KBИ cap is 100pf. Protects the grid if the flame hits the feedback capacitor. I would also recommend using several small power ceramic caps like K15Y of value 3-10 pF as a feedback variable capacitor instead of copper plates that are usually used. With them the 100 pF КВИ can be omitted.
That schematic works really well, but don't expect much more than 15-20 cm flame from GK-71. That is a good 1000+W already while the tube is 200-400W rated only, and 30-40 cm are 4+kW.
Sun Jul 22 2012, 10:42PM
I ordered 1mm copper sheet for this project, so there should be no problem.
But this string of small caps as feedback connection might be interesting on an aesthetic point of view !
About flame height, have a look at this video : Link2
zrg
Thu Jul 26 2012, 02:15AM
That is much more than a tube can carry on long runs. Also the flame is enhanced with a salt which gives +50-100% of length ;) but surely you can try to tune it better, it you believe that it is possible.
radhoo
Thu Jul 26 2012, 09:59AM
GK71 has some great potential, so good look with this project, looking forward to your first results!
Wed Aug 01 2012, 08:32AM
@zrg: I don't think salt increases that much flame height, at least it didn't at all on my 572B VTTC, but it was horizontal sparks and not vertical flame, so I'm not sure about this.
I know I won't be able to run the tube at full power for long times, I forgot to say in my project description it will be powered thru a variac, allowing longer runs at lower power.
@radhoo: Thanks smile
____________
I just received my ceramic coilform amazed
(I noticed there are two resistive wires wound in opposite direction, probly to cancel inductance)
Imag1111
