  • Guests: 26
Desmogod (48)
Alex Smith (31)
04/26 Bead (41)
04/26 Fumeaux (25)
04/28 Steve Conner (46)
GK71 HFVTTC 30cm Flames
RateReducer
Sun May 27 2012, 08:21PM Print
RateReducer Registered Member #4603 Joined: Wed Apr 25 2012, 07:33PM
Today i was bored. So i rebuild my GK71 tweeter.
New secondary has 14 turns of 2mm enameled wire on a 55mm cardboard pipe. Somewhere between 20 and 30Mhz. The choke has the same dimensions.
I used flat copper for the Anode, the ground connection an the feedback.
Power supply is a MOT with bridge rectifier + some microwave caps.
Dsc0282h
Dsc0284s
I am quite satisfied with this result smile
Greetings
Sun May 27 2012, 10:16PM
wow, thats awsome, i want one so bad D:
RateReducer
Mon May 28 2012, 04:15PM
Thanks, Tom Williamson!
It is not that hard to build one. wink
Here is a new video getting 30cm flames!
I just increased the topload capacitance and added some chemicals on the breakoutpoint.
The ruler is 30cm in lenght...
I like that tube so much! amazed
Mon May 28 2012, 11:27PM
So the choke is wound on the same form as the resonator? Does the coupling between them have any effect?
Pinkamena
Tue May 29 2012, 12:41AM
Pinkamena Registered Member #4237 Joined: Tue Nov 29 2011, 02:49PM
Looks like an expensive and dangerous candle XD
Tue May 29 2012, 05:02AM
Looks good and its a massive output for a tube running with cold plates. I got a good deal of tubes that size, maybe its time for a quick hfvttc as you did :)
RateReducer
Tue May 29 2012, 10:30AM
@Weston: Yes. I don´t know, i never tried to vary the distance between the 2 coils. But i think it does not matter.
@Pinkamena: That is true! xD
@Mads Barnkob: Thanks! :) It stays cold for about 30 seconds or so, than it gets slightly dark red.
"maybe its time for a quick hfvttc as you did :)" Try it! It is very simple and fun!
Greetings
TwirlyWhirly555
Tue May 29 2012, 03:27PM
TwirlyWhirly555 Registered Member #4104 Joined: Fri Sept 23 2011, 06:54PM
Very Nice ,as its a pentiode are you running both grids togethere ( G1 / G2 ) ?
RateReducer
Tue May 29 2012, 05:06PM
Thanks.
Grid 1 is for the feedback.
Grid 2 is on supply +. (11,7k)
Grid 3 is on ground.
I could try to connect G1 and G2...
Greetings
zrg
Sun Jun 03 2012, 02:49PM
zrg Registered Member #4762 Joined: Sun May 06 2012, 05:59PM
Well, that's a really well tuned flame discharge generator, I must say.
Being inspired by OP, remade my old GK-71 tweeter. Parameters are quite similar to OP's: ~30 MHz frequency, MOT with full-bridge rectifier and 2uf capacitance, 11k from + to grid 2, 10k from grid 1 to cathode, three power ceramic doorknob USSR caps (K15Y-1) 15 pf each in series, from secondary end to grid 1, as a capacitive feedback.
Plate becomes red-orange after ~20-30 sec run, probably because of no tuning at all tongue
