  • Guests: 32
M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
12/16 william L (29)
Coilgun cap recharging?
currentkills91
Sun Jun 12 2011, 05:57PM Print
Okay, so I've read that people have used a setup of diodes to partially recharge the capacitors after firing. I cant remember where I read this, but the idea is to use diodes to take the negative pulse after your gun is fired and feed it back into the caps at the right polarity. Can you even do this, cause that's a really big pulse to be sending into capacitors, also, how would you even do that anyway?
Ash Small
Sun Jun 12 2011, 06:20PM
I think I read a post along those lines. I don't think it was used to re-charge the capacitor, but to by-pass the capacitor, so the current keeps circulating through the coil.
It was a fairly recent post, I think, only a week or two ago. Shouldn't be too difficult to find.
currentkills91
Sun Jun 12 2011, 08:03PM
No that's not it, I've read about that too though. I read about it some time ago, like 2 months back. I was just curious about how something like that would work. :)
Mon Jun 13 2011, 12:24AM
You're thinking of a diagonal half bridge design. This is a bit more complicated than the usual single-SCR design because it requires two triggers to manage the timing. However, as you expected, it does recover the leftover energy and it does help turn off the coil at the right time. It can be built with an SCR, IGBT, MOSFET or other silicon devices.
It hasn't been done very often by coilgun hobbyists. Wouldn't it be nice if there were some motor-controller chip that can simplify the design? I've never looked into it, but it's a tantalizing prospect to adapt a good commercial controller chip to this purpose.
Cheers, Barry
Life is like an analogy.
currentkills91
Mon Jun 13 2011, 01:08AM
Hmm...How exactly would you do it? Is there a schematic somewhere I can look at?
Electroholic
Mon Jun 13 2011, 04:25AM
Same as the H-bridge, but each leg will have 1 diode and 1 switch. Also, if leg A has the switch on the high side, leg B will have the switch on the low side. hence the name diagonal half bridge.
Mon Jun 13 2011, 12:41PM
Google is your friend.
One place to start is this simplified sketch from 4hv history. Note it does not show triggering circuits or component values.
In response to your original question: Yes, you can design circuits to recover leftover energy from current circulating in the coil. It requires active circuitry; no arrangement of diodes alone can accomplish the task.
Cheers, Barry
currentkills91
Tue Jun 14 2011, 12:44AM
Hey, thanks so much for the replies everyone :)
Saz43
Tue Jun 14 2011, 05:13AM
Barry wrote ...
There is such a chip, it's called a high side/low side driver. It's actually quite simple to implement for a coil-gun, not nearly as hard as some would make it seem. For example, the ir2110 which (even as a beginner) I have had great success with: Link2
Link2 This guy built a nice half-bridge coilgun which gets 4.66% efficiency with one stage using a similar chip. He includes a schematic which shows that it's really not too complex.
Also, Link2 this guy built a 3-stage gun, which gets upwards of 10% efficiency in the half-bridge stages.
