  • Guests: 19
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
Linux boot times
Coyote Wilde
Sun Sept 23 2007, 12:15AM Print
Coyote Wilde Registered Member #175 Joined: Tue Feb 14 2006, 09:32PM
I don't know about you, but power wastage aside, I'd be alot more inclined to turn off my computer when I go away from it if it didn't take so dang long to power down and boot up again. I'm just running a default kubuntu setup right now-- which is far from ideal, I'm sure, but does anyone have some tips to speed up the boot that won't cause it to bog down too much starting programs?
I think bjorn mentioned something about this vis a vis battery life in the one-laptop-per-child discussion a while back, using it as rational to not pick linux for that sort of app.
This has also been given to me as a reason to switch to Gentoo, but I don't think I'm ready for anything that drastic... and from what I've seen, the improvement seems marginal anyway.
Any discussion?
Sun Sept 23 2007, 01:38AM
Well, there is suspend/hibernate...
Short of that, just turn off all of the services you don't need in system->services (make sure that you disable them in all runlevels)
Alex
Sun Sept 23 2007, 02:53AM
Alex Geometrically Frustrated
Registered Member #6 Joined: Thu Feb 02 2006, 04:18AM
There are threads on the Ubuntu forums about speeding up the boot process, it involves turning off services and starting X earlier, for the most part. Depending on how things are set up, you might be able to speed things up a lot. Alternate boot methods are more dangerous, but some allow you to start certain things up in parallel.
Compiling a new kernel without all of the extra crap that the default one has may also help.
krenshala
Sat Jan 05 2008, 02:20AM
krenshala Registered Member #143 Joined: Sat Feb 11 2006, 04:25PM
Boot time is entirely based on what the system is trying to start up between when you power it on and it gives you the logon prompt. I used Slackware and now Gentoo specifically because it would only run what I installed on the system. Removing/disabling unused services is the best way to improve both start-up times and general system performance (especially in Windows). Just be sure the service you want to kill is really "unused". ;)
