  • Guests: 78
projectiles??
lewylln
Fri Nov 05 2010, 05:39AM Print
lewylln Registered Member #3358 Joined: Mon Oct 25 2010, 09:47AM
greetings and salutations forum
i have (finally) finished construction of the barrel for my rail gun (woooo) and everything is working perfectly. with the exception of when it comes to firing, the capacitors fully charge (11 camera flash caps) and the circuit, firing switch etc all function perfectly, the rails have minimal resistance and my projectile as far as i know conducts from previous attempts. HOWEVER because I'm only human there is roughly a 1/3mm gap either side of the projectile inside the barrel, and somehow this has stopped any current flowing through it. this is highly annoying and my projectile (a cut off from a 3 inch nail, blunted of course) is nearly impossible to modify without a forge. So my question to you guys is this, can you think of a good solution short of building a forge in my garage to this problem, i was thinking of some easy way to mass produce projectiles of the appropriate size seeing as from what i can tell its what a lot people seem to be doing (somehow)
any ideas and comments would be A LOT of help ^.^
Artikbot
Fri Nov 05 2010, 08:47AM
Artikbot Registered Member #3247 Joined: Mon Sept 27 2010, 09:42AM
Where have you placed the projectile?
Fri Nov 05 2010, 11:26AM
Try a small ball of aluminium foil as your projectile. A nail is probably too big and heavy for your current capacitor bank.
lewylln
Fri Nov 05 2010, 07:10PM
ok that sounds logical, ill try it today and get back to you guys soon enough
and i placed the projectile between the two plates at the front? of the barrel where i have the wires from the cap bank hooked up
Artikbot
Fri Nov 05 2010, 07:59PM
I thought "D'oh it's a railgun not a coilgun" right after reading your reply x.x
So yes, in this case your projectile might be way too heavy for that energy. As GhostNull said, it's too heavy for that amount of energy.
