  • Guests: 30
Jim_VE7UV (65)
07/24 Jim_VE7UV (65)
07/26 Jorrit (39)
07/26 e.m.c.2 (45)
Ideas for vintage transformer
Anoki
Thu Nov 04 2010, 07:35AM Print
Anoki Registered Member #3249 Joined: Mon Sept 27 2010, 08:42PM
At a local surplus store today I found what looks to be a heavy duty magamp or pulse transformer. It weighs over a kilo, and has a strip wound, toroidal core with about a 2cm^2 cross section. windings are in two symmetrical and series connected groups. The single layer of windings closest to the core look like 18-20AWG, and the single layer of windings over the first are approximately 40 turns of 8AWG. At no point is the electrical insulation less than 2mm thick. The only markings on it are "407-295" "114-P-77" "23852". I couldn't find a reference for a #407 or a #114 company, and I am at a loss as to who the manufacturer might be.
Any ideas for identification or fun uses? I'm thinking it could easily handle 3-4 kv under oil...
radiotech
Fri Nov 05 2010, 04:19AM
Does it look like this? This is a magamp that works at 60HZ.
1288930790 2463 FT99920 Bampxfm
radiotech
Fri Nov 05 2010, 04:25AM
This is a magamp 60 Hz. Is yours similar ?
1288931096 2463 FT99920 Bampxfm
Anoki
Fri Nov 05 2010, 05:23AM
It does indeed, only more compact with fewer turns and no core laminations separating the winding legs...am I right in thinking these can basically be used like low freq magnetic transistors?
radiotech
Fri Nov 05 2010, 06:38AM
Firstly, my apologies for double posting. If there was an award
for fumblekeyboarding, I would win.
They act as variable inductances controlled by the DC winding.
To start with, see if you can dim a lightbulb with a DC voltage
from something like a 6 or 12 volt battery capable of an amp or so
conneced to the small wire winding. The single layer of # 8 is good
for about 40 amps. Analyse the core area and winding at 60, 400,
and 800 cycles to see what voltage would bring the core to about
1.5 Tesla.
