  • Guests: 40
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
A relay from tesla's time.
Adam Munich
Sun Oct 31 2010, 05:58PM Print
I'm a sucker for old electronics so when I saw this relay a few years ago at an antique mall for ten bucks I had to buy it. I'm still looking for an original AVOmeter.
It's a relay made by Weston Electric company in 1917. It has a 24V coil with a SPDT 24VDC contact. So why even bother? Only thing I can think of is an isolation relay. It has a giant magnet of unknown composition, maybe AlNiCo.
1288547518 2893 FT0 Dsc06882 1288547635 2893 FT0 Dsc06892 1288547486 2893 FT0 Dsc06886 1288547602 2893 FT0 Dsc06888 Zvbqdd
The relay works OK, and AFAIK it's the last one of it's kind remaining (SPDT). Some guy on the internet has some other models, but they are SPST. I'd like to put it to good use, but what should I make it do? It's not like it's going to burn out any time soon.
Edit: Oops, I forgot pics of the bottom. I removed the sheet metal cover so you can see things, and I also removed the cardboard spring cover too.
PdAMj
There are some inductors there, one bigger than the other. No clue what they do.
A7K19
All the springs are adjustable, so I can change the tension of the "swingy part". This means I can make the coil run on any voltage I want (no more than 32V though).
Mon Nov 01 2010, 06:33AM
Use it in an antique/steampunk circuit? Maybe that completely metal package circuit you've been dreaming of?
Dr. Slack
Mon Nov 01 2010, 08:03AM
It's not an isolation relay, it's a measurement and control relay. Look at the min and max operate voltages on your 5th picture.
Use a variable power supply and a DMM to see if it's in spec. I suspect you can adjust the voltage it switches at by altering the tension of the "swingy part".
Mon Nov 01 2010, 08:11AM
Thank you for showing us your lovely and enviable treasure.
You could use it to start a generator when your battery bank voltage runs low.
Similar "wrought" magnets are also found in old telephone magnetos and meters like this one:
1288598413 2099 FT99707 Dscn1005
I wish I knew what the magnets are made of -- presumably some kind of steel. They predate Alnico, which AFAIK is always a cast alloy that is notably brittle and coarsely grained. (By the way, beware of references which fail to mention that the principal component of Alnico is iron.)
The quest to improve magnetic softness (for transformers & motors) and magnetic hardness (for permanent magnets) must be an interesting story. If you'll pardon a quote from the W reference: "The development of alnico began in 1931, when T. Mishima in Japan discovered that an alloy of iron, nickel, and aluminum had a coercivity of 400 oersted (Oe), double that of the best magnet steels of the time."
Adam Munich
Mon Nov 01 2010, 11:52AM
Well it's definately out of spec because I was playing with the spring to see how low a voltage it could operate on. 1.7 volts seems to be the minum.
I also cleaned up the magnet before I took these pictures. It was patch-ily yellowed in some places so I cleaned off the patina with a paintbrush dipped in HCl. It bubbled for about half a second and a rotton egg odor appeared, probably hydrogen sulfide. The acid didn't affect the magnet itself.
So what forms a sulfur patina and doesn't react with HCl? It wasn't AlNiCo or the acid would've attatcked the magnet.
radiotech
Thu Nov 04 2010, 07:41AM
Perhaps the relay could be called a D'arsonval polar relay.
Can it be calibrated to be a SPDT-CENTER-OFF unit ?
Here is a place where the relay is used;
1288856458 2463 FT99707 Schematic Ksrelay
