  • Guests: 34
  • Most ever online: 596
    Guests: 596, Members: 0 on 25 Oct : 21:25
WaveRider (62)
Njubster (34)
10/30 Aragorn (41)
10/31 Tor (40)
10/31 RussT (67)
Using a desktop scanner to take x-ray photos
Download
Mon Oct 25 2010, 11:29AM Print
Download Registered Member #561 Joined: Sat Mar 03 2007, 02:46AM
Long time, no post
So I've been thinking, could it be possible to use a desktop scanner to pick up x-rays? If you put a piece of thick, black card on top of it and disabled the lamps it might pick up x-rays? You would have to use an x-ray scanner that lacks mirrors though which might be a bit of trouble as there might not be any scanners without mirrors.
Anyone see any flaws in this plan?
Mon Oct 25 2010, 12:12PM
The x-ray optics are the obvious problem.
You could take an x-ray film photograph an scan it !
How about an X-Y plotter with an x-ray sensor/detector ?
Wolfram
Mon Oct 25 2010, 12:50PM
Henning Umland tried this, with some results Link2 .
I started a thread some years ago with a similar idea, though with a fluorescent screen instead of the piece of paper. It can be found here Link2 . I think it could give excellent results. The key is to shield the scanner probably, and as Plazmatron wrote, this is not easy with LiDE scanners.
Anders M.
Tue Oct 26 2010, 07:32PM
thanks to Proud Mary I have two of these screens, used for X-ray film,
should work well if the screen is shielded (so light doesen't affect the linear CCD)
someone needs to try and make a homemade CT scanner... :)
-A
Adam Munich
Wed Oct 27 2010, 01:02AM
Remove the lamp and scan the light from the intensifying screen? A lot of scanners have LED lamps now, and in black and white mode they scan with a green light anyway.
Download
Wed Oct 27 2010, 07:34AM
I'm liking the idea of a scanner with a slab of lead glass on it and a fluorescent screen, I'll have to get the screen though
