  • Guests: 60
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Edge triggering in PIC
TheMerovingian
Thu Oct 21 2010, 09:34PM Print
When i'm using the edge triggering in PICs what is the minimun voltage swing needed for detection. I could not find anything about that
Lethal Shot
Fri Oct 22 2010, 10:25AM
Lethal Shot Registered Member #1623 Joined: Tue Aug 05 2008, 03:31PM
It depends on which PIC your using and if the ports are TTL or smith triggered.
For a PIC18F4550 the values are:
Low threshold 0.8V (TTL) and 0.2*VDD (smith trigger) assuming supply voltage is 4.5V or more.
High threshold is 2.0V and 0.8*VDD respectively.
But to be sure check the datasheet under 'Electrical characteristics' and then 'DC characteristics'.
TheMerovingian
Fri Oct 22 2010, 07:15PM
thank you :D. So the threshould in edge mode are the same. Perfect!
