  • Guests: 32
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
photocoupler
Thu Oct 21 2010, 03:40AM Print
I just got some photocouplers to play with.
Not having used these before, I wanted to make sure I was not going to destroy them. I have a 600v isolated voltage I want to measure on a 15v system. If I am reading the datasheet correctly, it says the typical current on the input is 20ma. I was going to put a 30k resistor in series with the voltage to achieve this current (Rd on page 8). I can then scale Rload as needed using Vcc = 15v for reading the output voltage. Is this reasonable?
Jrz126
Thu Oct 21 2010, 10:36AM
Yes, sounds reasonable, but your limiting resistor will be dropping 598V and at 20mA, thats almost 12 Watts.
Is the 600V signal AC or DC?
Thu Oct 21 2010, 11:14AM
Wouldn't it be more usual to convert the voltage to be measured into a pulse train by means of a divider network and V-F converter, and transmit that across the coupler?
Thu Oct 21 2010, 05:28PM
If you look at Fig.6 Current Transfer Ratio vs. Forward Current
you will see that CTR varies with current so you will get almost a square-law response.
One method is as above, V to F
I'd probably go for an IL300 Link2
or HCNR200 Link2
Bjørn
Thu Oct 21 2010, 10:07PM
Such optocouplers are not designed to transfer an analog signal so the the voltage to frequency suggestion is very sensible if you want accuracy and long term stability.
Fri Oct 22 2010, 09:53AM
The ones Sulaiman suggested are designed to transfer analog signals with high linearity. But they need an op-amp drive circuit on the high voltage side, and that needs isolated power. (As would a V-F converter.)
A regular optocoupler won't work, because the CTR varies so widely.
