  • Guests: 57
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Capacitor Datasheet Rating Question
ScotchTapeLord
Tue Oct 19 2010, 01:40AM Print
For certain series, it gives Irms at 100kHz and -70 degrees C.
-70? Is that supposed to mean less than 70 degrees or does that imply that these capacitors require liquid nitrogen cooling? :P
Tue Oct 19 2010, 03:30AM
I do only see down to -60 degress in the linked pdf, but its just within the milspec range... giving a current rating at the lowest temperature would also give an unatural high current ability... still didn't see that 100kHz rating in your link...
ScotchTapeLord
Tue Oct 19 2010, 03:57AM
On pg 10 and 12, after ESR, before dimensions.
"IRMS @ 100kHz -70 Celsius" (don't know how to do the degree symbol)
Tue Oct 19 2010, 05:05AM
Since the rated temperature range is -40 to +85
you can assume that the Irms figures are for +70 Celcius.
ScotchTapeLord
Tue Oct 19 2010, 12:06PM
Then what's with the negative sign? x_x
I've looked at some other data sheets and have seen IRMS at 100kHz 70 C but never with the negative sign....
Tue Oct 19 2010, 12:36PM
What if it were just a dash, as in 100kHz -- 70'C
ScotchTapeLord
Tue Oct 19 2010, 02:01PM
I had considered that... just wanted to hear it from someone else. It's just that they don't use that kind of notation anywhere else on the sheet.
Thanks, Steve.
Thu Oct 21 2010, 01:49AM
I think it's just a typographical error or transcription mistake.
Reminds me of datasheet for a very small mercury wetted relay, 30 years ago.
One row in the table gave the orientation requirement: vertical +/- 30 degrees Celsius.
