  • Guests: 34
  • Most ever online: 596
    Guests: 596, Members: 0 on 25 Oct : 21:25
WaveRider (62)
Njubster (34)
10/30 Aragorn (41)
10/31 Tor (40)
10/31 RussT (67)
using a ge lucalox as a x-ray generator?
Mon Oct 11 2010, 02:19PM Print
803 Registered Member #2807 Joined: Fri Apr 16 2010, 08:10PM
All this x-ray talk has made me wounder if this is possible. IS it?
youknow, it's in a vacuum, it's big, it sounds perfect
Adam Munich
Mon Oct 11 2010, 05:23PM
It may work, but I really doubt GE bothers to pull those bulbs to a high vacuum. They likely just put a noble gas in there and pull them to a low vacuum like a regular lightbulb. After all the Na envelope is what makes all the light; the bulb is just there to block UV.
Mon Oct 11 2010, 05:24PM
it has a getter and says in the data sheet that it has a vacuum
Adam Munich
Mon Oct 11 2010, 05:27PM
Well I suppose there's only one way to find out then. Keep in mind you'll never get a sharp picture from it though.
Mon Oct 11 2010, 06:39PM
o, I don't want to do it, i have no meter or shelding! how about you?
Adam Munich
Mon Oct 11 2010, 06:41PM
My geiger counter is broken, but I have a sh*tton of lead. If I ever get a new geiger counter, I'll try this for you.
